LQSC Class D Stereo Amplifier Module TPA3116 Bluetooth 5.0 2x50W 4 Ohm
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a high efficiency, higher than 92%, while offering a clear and detailed reproduction. It also integrates its own volume control allowing to easily adjust the volume level.
Reference : 17378
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 23-04-2025.
LQSC Amplifier module
Class D Stereo TPA3116 Bluetooth 5.0 2x50W 4Ω
LQSC Module amplificateur stéréo Class D TPA3116 Bluetooth 5.0 2x50W 4Ω
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a high efficiency, higher than 92%, while offering a clear and detailed reproduction. It also integrates its own volume control allowing to easily adjust the volume level. The amplification chip is topped by a heat sink to efficiently evacuate the heat released. An additional supplied fan can also be connected to the module for further dissipation. The module also benefits from a complete protection circuit against overvoltage, undervoltage, overcurrent, overtemperature and short-circuit.
On the connectivity side, the input is made in Jack 3.5mm or via a connector XH2.54mm 3 pins. A Bluetooth 5.0 reception chip allows it to broadcast its music remotely from a smartphone or a tablet for example. The Bluetooth antenna can be remote for an easy integration in the box thanks to a U.FL connector (external antenna sold separately). The output to speakers is done using screw terminals.
19-24VDC power input
2External fan connector
3ON/OFF switch
4Right channel speaker output
5Left channel speaker output
6Jack 3.5mm input
7Analog audio input on XH 2.54mm 3 pins connector
8U.FL connector for external Bluetooth antenna
9Bluetooth antenna
Product typeAmplifier module
Amplification typeClass D
Amplification chipTPA3116
InputsBluetooth 5.0
1* Jack 3.5mm
1* Analog audio input on XH 2.54mm 3 pins connector
OutputsScrew speaker terminals
Additional connectors1* 2 pins XH2.54mm fan connector
1* U.FL connector for external Bluetooth antenna (sold separately)
Output power2*50W @ 4Ω, 1% THD+N
2*33W @ 8Ω, 1% THD+N
Efficiency> 92%
THD+N< 0.2%
Gain32dB
ProtectionsShort circuit
Overcurrent
Overheating
Under voltage
Over voltage
Supply voltage9-24VDC via Jack DC 5.5/2.1mm (power supply sold separately)
Total dimensions71.4*54*22mm
Mounting holes spacing36*47.6mm
Package1* Amplifier module
1* XH2.54mm 3 pins cable
1* Fan
InputJack 3.5mm
InputXH 2.54mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)50.0
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a...
