This power amplifier kit has an effective power of 2x15W in a very small format.
Despite its small size, the sound quality is truly exceptional and will surprise even the most critical listener.
Perfect for bookcase speakers, compact systems, computer speakers etc...
Based on a Tripath architecture in Class-T™, the T-amp has an 80% efficiency.
Features:
- Output on terminal blocks
- Inputs on flexible wires
- Protected against overheating
- The signal fidelity is equal to that of high quality class AB amplifiers
- 400V capacitors 1.0µF
- Warp:
- 0.04% THD+N@9W, 40hm
- 0.18% IHF-IM@1W, 40hm
- Power :
- 15W@40hm, 10% THD+N
- 10W@80hm, 10% THD+N
- Yield :
- 81%@15W, 40hm
- 88%@10W, 80hm
- Signal-to-noise ratio = 102 dB
- PCB dimensions: 90 mm x 55mm x 55mm x 20 mm
- Power supply: 12V DC 2A (via PH 3-pin male connector)
