Module Amplificateur Mono TDA7293 1x100W / 4 Ohm
This Mono Amplifier module is based on the use of a high power TDA7293 transistors developed by the Swiss firm ST MicroElectronics.
It is capable of delivering a continuous power of 1x 100W under 4Ω.
The filtering is ensured by 2 electrolytic capacitors 50V Chemi-Con of 5800uF each.
Reference : 17640
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 22-04-2025.
Amplifier module Mono
It has a UPC 1237 chip which protects your speakers.
Make sure you have sufficient heat dissipation.
Amplifier chip1x TDA7293
AOPLF353P
Power supply28-0-28 V (AC)
Continuous power100W / 4 Ohm (10% THD+N)
Dimensions90x90mm
Spacing82mm
Weight120g
Package1x Amplifier module
Supplied with screws (spacers, insulator, etc.)
InputPCB Connector
OutputScrew terminals
Channel1 (Mono)
ClassClass A / AB
Amplifier chipTDA7293
Power (W)100.0
This Mono Amplifier module is based on the use of a high power TDA7293 transistors developed by the Swiss firm ST MicroElectronics. It is capable...
