Module Amplificateur Stéréo UPC2581 IRFP9240 Class AB 2x 125W 4 Ohm
This Class AB amplifier module allows to develop a consequent power of 2x 125W in a compact form factor. It is based on the use of 25C5171, 2SA193, 2SC5171 transistors (four transistors in total), IRFP240 and IRFP9240 power MOSFETs and a UPC2581 voltage amplifier chip.
Reference : 15526
51,90 €tax incl.
43,25 € tax excl.
Shipping date: 25-04-2025.
Amplifier board
Stereo UPC2581 IRFP9240 Class AB 2x 125W 4 Ohm
Module Amplificateur Stéréo UPC2581 IRFP9240 Class AB 2x 125W / 4 Ohm
This Class AB amplifier module allows to develop a consequent power of 2x 125W in a compact form factor. It is based on the use of 25C5171, 2SA193, 2SC5171 transistors (four transistors in total), IRFP240 and IRFP9240 power MOSFETs and a UPC2581 voltage amplifier chip. It benefits from a careful design with a protection circuit for loudspeakers using a UPC1237 chip and Omron relays but also Siemens decoupling capacitors and metal film resistors with a tolerance of 1%. This architecture allows to provide a high power while promoting a clear and detailed sound reproduction.
The quiescent current of the module is to be set at about 7mV DC via the variable resistors and the test terminals tp1/tp2 and tp3/tp4. A first approximate setting should be made when the module is first switched on, then a second one about 20 minutes later, once the module has stabilized in temperature, for a reliable setting.
Module amplificateur stéréo UPC2581 IRFP9240 Class AB 2x125W 4Ω
Product typeAmplifier board
Amplifier typeClass AB
Output power2x 125W
Output impedance4-8Ω
THD< 0.002%
InputsAnalog input on PCB connector
OutputsSpeaker output on screw terminal
Supply voltage36VAC (on screw terminal)
Dimensions168 x 85mm
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)125.0
Propre !
C est pas mal généreux en puissance, une précision redoutable dans les basses fréquences c est moins bien sur les médiums aigus mais ça fait le taf. Ça chauffe peu, même à volume fort. Pour le prix c est parfait. Alimenté avec un bon transfo et un pré ampli correct il y a de quoi faire de la musique
This review has been posted for Module Amplificateur Stéréo UPC2581 IRFP9240 Class AB 2x 125W 4 Ohm
This Class AB amplifier module allows to develop a consequent power of 2x 125W in a compact form factor. It is based on the use of 25C5171, 2SA193,...
