bien reçu, et installé, tout marche à merveille !! nickel !
This module Amplifier mono is based on the use of a pair of high-power transistors TDA7294 developed by the Swiss firm ST MicroElectronics.
It is capable of delivering a continuous power of 100W under 4Ω with a maximum harmonic distortion rate of 10% over an audible range from 20Hz to 20kHz.
Equipped with a very high thermal stability, it is equipped with a sophisticated protection system against overloads and overvoltages.
The filtering is ensured by 2 electrolytic capacitors 50V Chemi-Con of 6800uF each.
It has a speaker protection circuit UPC1237 with Omron relay.
Features:/ Strong>
Input | NC |
Output | Screw terminals |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | TDA7294 |
Power (W) | 100.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
