Mono Amplifier Module TDA7293 1x150W / 4 Ohm
This Mono Amplifier module is based on the use of high-power TDA7293 transistors developed by the Swiss firm ST MicroElectronics.
It is capable of delivering a continuous power of 1x 150W under 4Ω.
Reference : 17639
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 24-04-2025.
MONO AMPLIFIER MODULE
Make sure you have enough heat dissipation.
Technical Characteristics
Amplifier3x TDA7293
Power supply±(35-45) V DC
Continuous power150W / 4 Ohm (10% THD+N)
Output Impedance4-8 Ohm
THD< 0,01 %
Frequency response(-3dB) : 20Hz-20KHz
Dimensions120x50x30mm
Spacing112x42mm
Weight70g
Package1x Amplifier module
Supplied with screws (spacers, insulator, etc.)
InputScrew terminals
OutputScrew terminals
Channel1 (Mono)
ClassClass A / AB
Amplifier chipTDA7293
Power (W)150.0
This  Mono  Amplifier module is based on the use of high-power TDA7293 transistors developed by the Swiss firm ST...
