Mono Class D Amplifier Board IRS2092S 200W 4 Ohm
This compact mono amplifier module is capable of developing a comfortable power of 200W, thanks to the use of two IRS2092S chips, with a high efficiency of over 90% and a gain of +31dB. The whole circuit takes advantage of quality components, allowing to reach a low level of distortion for a musical and dynamic restitution.
2.0 / 5
Reference : 15591
39,90 €tax incl.
33,25 € tax excl.
mono Amplifier module
Mono Class D IRS2092S 200W 4Ω
Module amplificateur Mono Class D IRS2092S 250W 4Ω
This compact mono amplifier module is capable of developing a comfortable power of 200W, thanks to the use of two IRS2092S chips, with a high efficiency of over 90% and a gain of +31dB. The whole circuit takes advantage of quality components, allowing to reach a low level of distortion for a musical and dynamic restitution. A large heat sink allows to dissipate efficiently the heat generated by the amplification chips. The power supply is in +/-50VDC.
xxx
Product typeMono amplifier module
Input1x Analog input on screw terminal
Output1x Analog output on screw terminal
Output power200W
Efficiency≥90%
SNR90dB
THD≤ 0.05% @ 250W, 4Ω
Recommended speaker impedance4-8Ω
Supply voltage+/-50VDC on screw terminal (not included)
Dimensions86 x 56 x 29mm
Weight100g
InputScrew terminals
OutputScrew terminals
Channel1 (Mono)
Amplifier chipInfineon IRS2092
Power (W)200.0
Bon son, mais où sont les watts
Très déçu au niveau de la puissance
This review has been posted for Mono Class D Amplifier Board IRS2092S 200W 4 Ohm
This compact mono amplifier module is capable of developing a comfortable power of 200W, thanks to the use of two IRS2092S chips, with a high...
