Mono Power Amplifier Modules LM3886 2x120W / 8 Ohm (Pair)
This dual mono amplifier is equipped with no less than 4 LM3886 amplification chips in total, to deliver 2x120W at 8 Ohms and accompany your hifi system as required.
Reference : 12660
49,00 €tax incl.
40,83 € tax excl.
Mono amplifier modules LM3886
2x120W 8Ω
module amplificateur mono
LM3886 + AOP NE5532D
This amplifier is composed of two mono modules, each integrating 2 LM3886 amplification chips in Class AB, coupled to 2 AOP NE5532D mounted on DIP8, for a total of 4 amplification chips. With these components, the amplifier is capable of delivering 2x120W under 8Ω to efficiently power your audio system.
Double Mono design & pure DC amplification
The dual mono design (one channel per module) allows to separate the power supplies to obtain a cleaner current, to limit crosstalk and to obtain a much more aerated sound image.
To ensure true separation, each channel uses a high-gain Op Amp. This architecture results in deeper bass and dynamic high frequencies.
Speaker protection & Balanced architecture
Each module integrates a loudspeaker protection circuit using an Omron relay. Your high-end speakers have nothing to worry about with this amplifier.
In addition, to ensure high signal accuracy and noise reduction, these modules are based on a symmetrical architecture.
Quality components
Each module integrates high quality components, contributing to the sound quality of the product. For example, there are ELNA, Nover capacitors or an Omron relay.
  1. First power supply
  2. Second power supply
  3. Speaker terminal
  4. RCA XLR Switch
  5. XLR Input
  6. RCA Input
  7. Potentiometer connector
  8. Gain setting : LOW/HIGH
Potentiometer installation
The modules are mono bridge modules. This means that you need to use one stereo potentiometer (10K to 50K) per channel, or one 4-channel potentiometer. To do this, you need to remove the jumpers on the back of the board, using a soldering iron.
connection diagram for potentiometer
Product feeding: To properly supply this product we recommend that you carry out this Toroidal transformer 160VA 2x24V + 2x15V Standard profile.
Amplification chipLM3886
Power2x120W 8Ω
Power supply24V-0-24V + 15V-0-15V
InputsXLR
RCA
OutputsSpeaker terminal
AOP2x NE5532D
Dimensions (1 module)170 x 83 x 40mm
Weight280g each module
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
ClassClass A / AB
Amplifier chipLM3886
Power (W)120.0
This dual mono amplifier is equipped with no less than 4 LM3886 amplification chips in total, to deliver 2x120W at 8 Ohms and accompany your hifi...
