MA-LM03 Stereo Amplifier board LM3886T Class AB 2x 125W
Reference : 10220
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 23-04-2025.
This Class AB Stereo Amplifier is renowned for its dynamics and excellent low frequency performance.
It has two 10000μF 50V NOVER Audio rectifying filter capacitors, MUR1620 diodes and a C1237 speaker protection circuit with Omron relay.
It includes a start delay circuit and protection against overload and overheating.
Easy to implement and small format, it will prove an excellent choice for any DIY Amplifier project.
Characteristics :
  • Amplifiers LM3886T (2x2)
  • Output power: 2x 125W at 4 Ohms
  • Input Impedance: 47K Ohm
  • Recommended Power Supply: 27V - 0 - 27V AC
  • Dimensions: 176x86x49mm
  • Drilling spacing: 168mm, 77mm
  • Spacers, Screws, Mica Insulation supplied
  • Requires heat sink / radiator
  • Weight: 225g
InputNC
OutputPCB Connector
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipLM3886
Power (W)125.0
2 reviews
Très bien
Très bon produit, simple a mettre en œuvre (il suffit de lui associer le transfo et les connectiques). On se fait un ampli pour un prix modique.
Ensuite on peut facilement l'améliorer si on le souhaite.
This review has been posted for MA-LM03 Stereo Amplifier board LM3886T Class AB 2x 125W
Very good module
Bought this one a while ago. Took a bit for burn in, but after a while it got better every day. I compared it to several other amps and it surprisingly outplayed quite some of them. Not quite on level with my KT88 Tubeamp, but surprisingly close. Good soundstage, good imaging, god natural timbre & texture of instruments an voices. I added a small vishay bypass cap to the coupling caps, helped improving a bit on micro detail which I consider to be a rewarding little mod. i can recommend this board without drawbacks.
 (4)
