Stereo Amplifier Module Bluetooth 5.0 2x5W 8 Ohm
4.3 / 5
Reference : 14594
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 23-04-2025.
Bluetooth amplifier module
Stereo amplifier 2x5W Bluetooth 5.0
This extremely compact module allows you to easily integrate a Bluetooth 5.0 receiver and a stereo amplifier into your projects. It is ideal for all connected portable speaker projects. It already has all the necessary connections for an easy installation with a battery power port as well as a micro-usb port already installed to facilitate the charging of a battery.
Bluetooth 5.0
The module has a low power consumption bluetooth 5.0 receiver. The wireless interface is automatically active as soon as the power is turned on. Just pair your bluetooth source to the device named "DW-CT14 +" and the module is already ready to stream your digital audio streams.
When integrating the module into its housing, it is recommended to space the bluetooth antenna away from any metal part so as not to affect the effective range of the transmission.
If the module does not receive any signal for 10 minutes, it switches off automatically.
Connexion
Very easy to use, the module has two PH connectors dedicated to the left and right channels. Cables with the appropriate connector on the one hand, as well as bare wires on the other hand are provided to easily connect these outputs to your speakers.
A third connector (XH) is dedicated to the installation of a 3.7-5V lithium battery. Since the module does not have a protection or charge manager, this battery must necessarily integrate its own protection circuit. When a battery is installed, it can be charged directly via the micro-USB input.
Finally, it is also possible to power the module directly via the micro-USB connector.
A status LED confirms that the module is powered up.
TypeAmplifier module
Power5W 8Ω
10W 4Ω
Channelsx2
Power supply5V 2A
InputBluetooth 5.0
OutputsAux stereo (connecteurs PH)
Dimensions40 x 20 x 12mm
OutputXH 2.54mm
Channel2 (Stereo)
Amplifier chipN/A
Power (W)5.0
3 reviews
Petit mais...
Ce module marche plutôt bien, le Bluetooth ne décroche pas et la connexion s'établie sans soucis.
Sa taille et son alimentation lui permet de s'intégrer facilement n'importe ou.
La puissance est légère mais suffisante pour diffuser de la musique dans ma salle de bain.
le son est plutôt orienté vers le bas medium / grave , pas très équilibré mais reste écoutable pour de la diffusion.
il ne faut pas lui demander de la hifi il n'est pas fait pour ça.
il s'éteint automatiquement après quelques minutes mais ne redémarre pas tout seul (pas le mien).
il faut le rebrancher pour qu'il se rallume.
This review has been posted for Stereo Amplifier Module Bluetooth 5.0 2x5W 8 Ohm
Best
Meilleur mini amplificateur
Best
Meilleur mini amplificateur au monde
