SylphAudio D100 P02 PFFB Amplifier Module
The Sylphaudio D100 P02 Class D amplifier module is designed to deliver high-quality sound, including exceptional midrange clarity and transparency. It is based on a TI TPA3251 amplifier chip, renowned for its superior performance in these areas.
Reference : 18570
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 24-04-2025.
SylphAudio D100 P02 PFFB Amplifier Module Class D Stereo TPA3251 2x125W 4 Ohm
Sylph Audio D100 : Main view
The Sylph Audio D100 Class D amplifier module is designed to deliver high-quality sound, including exceptional midrange clarity and transparency. It is based on a TI TPA3251 amplifier chip, renowned for its superior performance in these areas.
The module features a versatile input stage for balanced and unbalanced signals. It is therefore compatible with a wide range of source devices.
The OPA buffer section has been designed with an independent power supply, avoiding the redundant use of coupling capacitors in the signal path. This design enhances sonic transparency and delivers a more detailed sound reproduction.
The module features an official ATS heatsink for efficient heat dissipation. This enables the amplifier to perform at its best, even when feeding demanding loudspeakers.
Finally, the module also features solder jumpers for setting the slave mode, as well as OSC IOM/IOP pads accessible under the PCB. This facilitates configuration for installations using multiple modules.
Recommended power supply:
  • SMPS power supply 36V to 38V DC, 200W or more
  • Do not use feeders with separate rails
  • Use 34V DC for unregulated linear power supplies
Sylph Audio D100 : Schéma de branchement
1Input 1
2Input 2
3Power supply input
4Left channel output
5Right channel output
Product typeAmplifier module
Amplification chipClass D
Number of channelsStereo (2)
Amplification chipTI TPA3251
Output power2x125W @ 4Ω, 1% THD+N
2x70W @ 8Ω, 1% THD+N
InputsBalanced and single-ended (solder pads under the module to select mode. Default: balanced)
Input sensitivitySingle-ended: 2.5Vrms
Balanced: 5Vrms
GainSingle-ended: 18dB (8x)
Balanced: 12dB (4x)
Load impedance4Ω or 8Ω
Dissipation~6.5W @ 36VDC
Supply voltageFrom 24VDC to 38VDC
Dimensions133 x 100 x 45mm
Package1x Sylphaudio D100 P02 PFFB module
2x XH 2.54mm 3 pins connectors
6x Crimp terminals
Sylph Audio D100 : Mesure canal gauche Sylph Audio D100 : Mesure canal droit
InputSolder pad
OutputSolder pad
Channel2 (Stereo)
Amplifier chipTPA3251D2
Power (W)125.0
Music
After AB class, this amp is opening new dimensions.
This review has been posted for SYLPH AUDIO D100 P02 PFFB Amplifier Module Class D Stereo TPA3251 2x125W 4 Ohm
The Sylphaudio D100 P02 Class D amplifier module is designed to deliver high-quality sound, including exceptional midrange clarity and...
