- Class D 2x110W sous 8 Ohms -
This module integrates the latest generation of Texas Instrument Purepath UltraHD technology with 100kHz bandwidth in HD audio formats. The integrated mosfet scanning error correction system allows accurate playback on a module with high power of 2X110W at 8 Ohm on a compact and simple integration board.
The input stage designed on two classic PDOs TL072 type FET works on an input voltage of 2V. It is possible to directly attack by a DAC with variable volume or by digital volume of a computer without dynamic adaptation and bandwidth problems.
The module has 2 ELNA ELA 5 electrolytic capacitors of 3900µF on 100V of high reliability to ensure a constant power supply. The control part uses the high-performance LM2575S. The output filter has audio inductances for smoother sound.
The LEDs on the circuit indicate the following functions:
Fault: Signal too high at input or output impedance on speaker terminals too high
OTW Clip: Overvoltage and under voltage and overheating
This module require a speaker delay board to avoid ON/OFF plop noise
Input | RCA |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 110.0 |
