TINYSINE TSA2210 Kit Class D Amplifier Module TPA3110D2 Bluetooth 2x8W + Volume Controller + LED
This small Class D amplifier module based on a TPA3110D2 chip capable of developing a power of 2x8W. It can be used with speakers with an impedance of 4Ω or 8Ω.
4.5 / 5
Reference : 13688
29,90 €tax incl.
24,92 € tax excl.
TINYSINE TSA2210
TinySine TSA2210 Kit Module Amplificateur Class D TPA3110D2 Bluetooth 2x8W + Contrôleur de Volume + LED
This TinySine kit consists of a Class D amplifier module, a volume controller and a status LED. The amplification module is based on a TPA3110D2 chip delivering a power of 2x8W and can be associated with speakers in 4Ω or 4Ω. It is also equipped with a Bluetooth AudioB Plus receiver from the brand, allowing you to simply stream your music from a smartphone or tablet, for example.
The supplied button therefore makes it possible to adjust the volume and also to switch the module on or off by pressing it. Volume can also be remotely controlled from the mobile brand application. The status LED indicates whether the module is on or off.
On your smartphone or tablet, the Bluetooth amplifier module will appear under the name "BT Speaker".
Product typeAmplifier module kit
Bluetooth version4.0
OutputScrew terminal
ProtectionsOver voltage, under voltage, overload, over temperature
Measurements
ParameterConditionsMin.Typ.Max.
Supply voltage-81216
Input sensitivityGain = 26dB-0.283V-
Input impedance--30KΩ-
Gain--26dB-
Power outputTHD+N = 10%, Vcc = 12V-8Wrms-
EfficiencyVcc=12V, RL=8Ω, PO=5W-86%-
Minimum load-3.2Ω4Ω-
Frequency response±3dB20Hz-22kHz
Operating temperature--40°C20°C65°C
Amplifier module dimensions80 x 48mm
Package1x Amplifier module TinySine TSA2210
1x Volume controller
1x LED (green)
1x Ribbon cable
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3110D2
Power (W)8.0
2 reviews
TINYSINE TSA2210
C'est mon deuxième ! Utilisés pour redonner une vie moderne à 2 vieux postes de radio TSF irrécupérables , le bouton en plastique de controle de volume ne s'enlève pas de son axe ce qui aurait permis de cacher le circuit imprimé !
This review has been posted for TINYSINE TSA2210 Kit Class D Amplifier Module TPA3110D2 Bluetooth 2x8W + Volume Controller + LED
Ideal pour petite enceinte portable diy
par contre attention haut parleur 8 ohms uniquement
sur des 4 ohms l'ampli plante au 3/4 du volume maxi
This small Class D amplifier module based on a TPA3110D2 chip capable of developing a power of 2x8W. It can be used with speakers with an impedance...
