TINYSINE TSA2210U Amplifier Module TPA3110D2 Bluetooth 4.0 CSR8635 + Volume Button
This kit is designed for professionals and DIY enthusiasts alike. It includes a volume knob, a moisture-resistant LED, a 2.4GHz antenna and a TSA2210U amplifier board and Bluetooth receiver.
Reference : 18186
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 16-04-2025.
TinySine TSA2210U
Module Amplificateur TPA3110D2 Bluetooth 4.0 CSR8635 + Bouton de volume
TinySine TINYSINE TSA2210U Amplifier Module TPA3110D2 Bluetooth 4.0 CSR8635 + Volume Button
This kit is designed for professionals and DIY enthusiasts alike. It includes a volume knob, a moisture-resistant LED, a 2.4GHz antenna and a TSA2210U amplifier board and Bluetooth receiver. Users can adjust the volume of the Bluetooth audio either via their smartphone, or using the supplied knob. The kit can be powered by a 12VDC power supply or a 12V battery. The LED can indicate ON/OFF status and battery voltage. The kit can be installed in a box to easily create your own audio amplifier.
The TSA2210U Class D amplifier board is based on a TPA3110D2 amplifier chip to develop 2x8W power at 8Ω. It can be powered by any DC 8-16V supply and will be able to drive any 4Ω or 8Ω passive loudspeaker. The volume control circuit is also integrated on this board. The Bluetooth 4.0 receiver uses a CSR8635 chip.
Product typeAmplifier board
Bluetooth receiver
Amplification chipQualcomm TPA3110D2
Bluetooth chipCSR8635
InputBluetooth 4.0
OutputScrew terminals
Quiescent current20mA @ Vcc=12V
Input sensitivity0.283V @ gain=26dB
Input impedance30kΩ
Gain26dB
Output power8WRMS @ Vcc=12V, THD+N=10%
Efficiency86%
Frequency response20Hz - 22kHz (+/-3dB)
Supply voltage10.3-16VDC (power supply not included)
Amplification board dimensions80*49mm
Amplification board mounting holes spacing70*40mm
Knob board dimensions50*26mm
Knob board mounting holes spacing40*16mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3110D2
Power (W)8.0
This kit is designed for professionals and DIY enthusiasts alike. It includes a volume knob, a moisture-resistant LED, a 2.4GHz antenna and a...
