Amplifier Module Class D TPA3110D2 Bluetooth 2x8W
This small Class D amplifier module based on a TPA3110D2 chip capable of developing a power of 2x8W. It can be used with speakers with an impedance of 4Ω or 8Ω. The card is equipped with a Bluetooth AudioB Plus receiver from the brand, allowing remote audio files to be streamed directly from a smartphone or tablet, for example.
As for connectivity, it is therefore possible to stream your files via Bluetooth but also to use the input in 3.5mm Jack format.
When a 3.5mm jack cable is connected, Bluetooth is automatically disabled.
Product type | Amplifier module |
Bluetooth version | 4.0 |
Inputs | Bluetooth Jack 3.5mm |
Output | Screw terminal |
Protections | Over voltage, under voltage, overload, over temperature |
Measurements | ||||
Parameter | Conditions | Min. | Typ. | Max. |
Supply voltage | - | 8V DC | 12V DC | 16V DC |
Input sensitivity | Gain = 26dB | - | 0.283V | - |
Input impedance | - | - | 30KΩ | - |
Gain | - | - | 26dB | - |
Output power | THD+N = 10%, Vcc = 12V | - | 8Wrms | - |
Efficiency | Vcc=12V, RL=8Ω, PO=5W | - | 86% | - |
Minimum load | - | 3.2Ω | 4Ω | - |
Frequency response | ±3dB | 20Hz | - | 22kHz |
Operating temperature | - | -40°C | 20°C | 65°C |
Dimensions | 80 x 48mm |
Input | Jack 3.5mm |
Input | Bluetooth |
Output | Screw terminals |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3110D2 |
Power (W) | 8.0 |
