TINYSINE TSA3116 Class D Amplifier Module 2x50W TPA3116D2 Bluetooth 4.0
This TinySine TSA3116 amplifier module capable of developing 2x50W under 4 Ohm is equipped with a Bluetooth 4.0 AudioB Plus module. In addition, it benefits from a Class D architecture thanks to a TPA3116D2 amplification chip, allowing it to benefit from an excellent efficiency.
Reference : 13631
33,90 €tax incl.
28,25 € tax excl.
TINYSINE TSA3116
Module Amplificateur Class D 2x50W TPA3116D2 Bluetooth 4.0
TINYSINE TSA3116 Module Amplificateur Class D 2x50W TPA3116D2 Bluetooth 4.0
This TinySine TSA3116 amplifier module capable of developing 2x50W under 4 Ohm is equipped with a Bluetooth 4.0 AudioB Plus module. In addition, it benefits from a Class D architecture thanks to a TPA3116D2 amplification chip, allowing it to benefit from an excellent efficiency of 90%. The module can be used to accompany passive speakers with an impedance of 4 or 8 Ohm.
This TSA3116 has a classic stereo RCA connector at the input as well as Blutooth 4.0 connectivity. So you can pair the amplifier with a compatible device (smartphone, tablet...) and stream your audio files simply from your sofa. Pairing is extremely simple since it is enough to search for a Bluetooth device from your source device and select the module called "BT Speaker".
In addition, the card includes a 5-pin BVC port for connecting a TinySine module for controlling the Bluetooth volume.
Product typeAmplifier module
ClassD
Power output2x50W @ 4 Ohm, THD+N = 10%
2x36W @ 4 Ohm, THD+N = 1%
Efficiency90%
Amplification chipTPA3116D2
Frequency response20Hz - 20kHz @ ±3dB
THD0.0299% @ 4 Ohm, 1W, 1kHz
0.073% @ 4 Ohm, 10W, 1kHz
Input sensitivity808mV @ 4 Ohm, 50W, 1kHz
Input impedance22 KOhm
Gain25dB
Bluetooth version4.0
Connectic1x BVC Port
ProtectionsOver/Under Voltage
Overload
Over temperature
Supply voltage10-24V DC
Dimensions9.5 x 6.9cm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
This TinySine TSA3116 amplifier module capable of developing 2x50W under 4 Ohm is equipped with a Bluetooth 4.0 AudioB Plus module. In addition, it...
