TINYSINE TSA7499B Amplifier Module Class D 2x100W TDA7498 Bluetooth aptX
TinySine's TSA7499B modules are Class D amplifiers that deliver no less than 2x100W at 6Ω. They are also combined with an AudioB Plus module to offer Bluetooth reception supporting aptX, for more convenient use.
Reference : 12876
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 22-04-2025.
TinySine TSA7499B
Amplifier Module Class D TDA7498 2x100W 6Ω Bluetooth aptX
TinySine TSA7499B
TinySine's TSA7499B module is Class D amplifier that deliver no less than 2x100W at 6Ω. It is also combined with an AudioB Plus module to offer Bluetooth reception supporting aptX, for more convenient use. This amplifier is based on a TI TDA7498 chip. The TSA7499B can be powered by any 14-39V DC power supply. In addition, in order to protect the heating components from possible deterioration, a fan makes it possible to cool the assembly. This is activated only above 65°C in order to reduce the noise emitted.
TSA4799B amplifier is designed specifically for DIY enthusiasts. Thus, you will have on this module a line/bluetooth input and an audio input in the form of JST connectors. Therefore, you can integrate this amplifier in a box and for example associate an external switch as well as an RCA or 3.5mm jack connector. To simply adjust the volume, you can also add a volume controller to this amplifier, like those in the TinySine TSA1000 series.
TinySine TSA7499B amplificateur class d 2x100W schema
Basic connection
Connection with external TSA1000 volume control
When mounting with a TSA1000, do not exceed a 24V DC power supply.
Amplifier chipTDA7498
Amplification typeClass D
Efficiency> 90%
Frequency response20Hz - 22kHz @ +-3dB
Output power2 x 100W @ THD=100% 6Ω
2x80W @ 8Ω
Input sensitivity1356mV @ 25.6dB
696mV @ 31.6dB
460mV @ 35.1db
341mV @ 37.6dB
Bluetooth version4.2
Supported protocolsaptX
aptX Low Latency
SBC
AAC
ProtectionsOver/Under-voltage
Over current protection
Over temperature protection
AlimentationJack DC 14-39V
Dimensions122 x 80 x 18.6mm
OutputScrew terminals
Channel2 (Stereo)
Power (W)100.0
TinySine's TSA7499B modules are Class D amplifiers that deliver no less than 2x100W at 6Ω. They are also combined with an AudioB Plus module...
