TINYSINE TSA7510B U.FL Class D Amplifier Module TPA3221 Bluetooth aptX TWS 2x100W
The TinySine TSA7510B is a Class D amplifier module capable of delivering 2x100W with a high efficiency of 90%. It can therefore be combined with passive speakers in 2, 4 or 8Ω. It also includes a Bluetooth AudioB Plus module, giving it a significant user comfort since you can broadcast your audio files directly from your smartphone or tablet.
4.0 / 5
Reference : 15696
57,90 €tax incl.
48,25 € tax excl.
Shipping date: 22-04-2025.
Tinysine TSA7510B U.FL
Tinysine TSA7510B Module Amplificateur Class D TPA3221 Bluetooth aptX TWS 2x100W
The TinySine TSA7510B is a Class D amplifier module capable of delivering 2x100W with a high efficiency of 90%. It can therefore be combined with passive speakers in 2, 4 or 8Ω. It also includes a Bluetooth AudioB Plus module, giving it a significant user comfort since you can broadcast your audio files directly from your smartphone or tablet. This Bluetooth module includes an SMA connector, allowing you to connect a Bluetooth antenna (sold separately) to it in order to improve transmission quality and maximum distance. In addition, the Bluetooth chip supports the aptX and aptX Low Latency protocols to improve transmission rate and stability in order to improve the quality of sound reproduction.
The TSA7510B also supports TWS mode. It is possible to combine two TSA7510B modules together to stream audio files to them at the same time.
The module is also versatile as it can be connected to other TinySine add-on modules (sold separately) such as the TSA1000, TSA1010 and TSA1020 volume controllers. An additional line output also allows you to connect a subwoofer to it.
Connection diagram
The TSA7510B automatically detects the audio input, with Bluetooth having the highest priority. When Bluetooth is disconnected or not used, the amplifier will use the AUX / Line outputs.
Operation of two TSA7510B modules in TWS mode.
Using the control buttons
  • S1 : Long press 3s to activate pairing mode. Long press 6s to reset the pairing information.
  • S1 + S2 : Long press 1s to activate the slave TWS mode.
  • S1 + S3 : Long press 1s to activate the TWS master mode.
  • S2 + S3 : Press and hold 1s to deactivate the TWS mode.
SpEcifications
Product typeAmplifier module
Power2x100W
Bluetooth Version4.2
Supported Bluetooth protocolsaptX
aptX Low Latency
SBC
AAC
TWS Mode supportYes
ProtectionsOver voltage, under voltage, overload, thermal protection
Dimensions122 x 80 x 18.6mm
InputsBluetooth (U.FL)
1x Stereo RCA
Outputs1x Speaker screw terminals
1x Jack 3.5mm
Other connectors1x BVC Connector
1x Control panel connector
Power supply (not included)10-26V via Jack DC 5.5/2.5mm
Measurements
ParameterConditionMin.Typ.Max.
Supply voltage-10V24V26V
Output powerRL = 3Ω, 10% THD+N-112W-
RL = 4Ω, 10% THD+N-105W-
RL = 3Ω, 1% THD+N-100W-
RL = 4Ω, 1% THD+N-88W-
THD+N1W-0.02%-
SNRA-Weighted, Gain = 18dB-108dB-
DNRA-Weighted, Gain = 18dB-109dB-
Minimum impedance-3Ω4Ω-
Gain-18dB24dB34dB
Efficiency100W @ 4Ω-90%-
Input impedance18dB-48KΩ-
24dB-24KΩ-
30dB-12KΩ-
34dB-7.7KΩ-
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3221
Power (W)100.0
Petit ampli très intéressant, qui trouve vraiment tout son sens en y ajoutant le câble et la liaison USB pour avoir accès au DSP. La qualité sonore restituée est vraiment agréable, le son est clair, et le DSP intégré permet de "tricher" un peu sur l EQ pour corriger certains trous de réponse en fréquence éventuellement, et forcer un peu la descente en fréquence de l'enceinte en ajoutant qqs DB à la f-3 par exemple. La fonction bass boost pour ma part m a servi à compenser le baffle step de manière numérique sans devoir complexifier mon crossover passif. On peut également jouer sur les effets de profondeur stéréo, utilisés dans mon cas pour redonner de l'espace à l'écoute dans une box bluetooth ( et ça marche très très bien, en prenant le temps d écouter et corriger de manière dichotomique ) . Le point "négatif" : je doute TRÈS fortement que les puissances annoncées soient celles restituées, c'est plus que certain....Cependant le volume (pilotes en 8 ohms dans mon cas de figure ) reste bien plus que largement suffisant pour une écoute domestique dans un salon de 20m2.
This review has been posted for TINYSINE TSA7510B U.FL Class D Amplifier Module TPA3221 Bluetooth aptX TWS 2x100W
The TinySine TSA7510B is a Class D amplifier module capable of delivering 2x100W with a high efficiency of 90%. It can therefore be combined with...
