TINYSINE TSA7600 Amplifier Module TPA3221 2x100W + 200W
The TinySine TSA7600 is a Class D amplifier module with 3 channels, capable of delivering 2x100W + 200W with a high efficiency of 90%. The module can be used to accompany passive speakers in 4 or 8Ω.
4.0 / 5
Reference : 13839
49,90 €tax incl.
41,58 € tax excl.
Tinysine TSA7600
Module Amplificateur TPA3221 2x100W + 200W
Tinysine TSA7600 Module Amplificateur TPA3221 2x100W + 200W
The TinySine TSA7600 is a Class D amplifier module with 3 channels, capable of delivering 2x100W + 200W with a high efficiency of 90%. The module can be used to accompany passive speakers in 4 or 8Ω. A fan protects the heating components by dissipating the heat. In addition, the amplifier incorporates overvoltage, undervoltage, overload and thermal protection.
Product typeAmplifier module
Power2x100W + 1x200W
Inputs3x RCA
Outputs3x Speaker screw terminals
ProtectionsOver voltage, under voltage, over current, thermal protection
Dimensions148 x 90 x 24mm
Weight152g
Measurements
ParameterConditionMin.Typ.Max.
Supply voltage-10V24V26V
Output power per channelRL = 3Ω, 10% THD+N-112W-
RL = 4Ω, 10% THD+N-105W-
RL = 3Ω, 1% THD+N-100W-
RL = 4Ω, 1% THD+N-88W-
200W Channel : RL = 2Ω, 1% THD+N-208W-
THD+N1W-0.02%-
SNRA-Weighted, Gain = 18dB-108dB-
DNRA-Weighted, Gain = 18dB-109dB-
Minimum impedance-3Ω4Ω-
Gain-18dB24dB34dB
Efficiency100W @ 4Ω-90%-
Input impedance18dB-48KΩ-
24dB-24KΩ-
30dB-12KΩ-
34dB-7.7KΩ-
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3221
Power (W)200.0
Power (W)100.0
joli son !
This review has been posted for TINYSINE TSA7600 Amplifier Module TPA3221 2x100W + 200W
The TinySine TSA7600 is a Class D amplifier module with 3 channels, capable of delivering 2x100W + 200W with a high efficiency of 90%. The module...
