TINYSINE TSA7804C SPDIF Amplifier Module TPA3116D2 DAC DSP 4 x50W
The Tynisine TSA7804C SPDIF amplifier module is a DSP amplifier module with 4 channels of 50W each. It's based on an SPDIFBee receiver module that converts the signal to I2S for transmission to the ADAU1701 DSP chip. This module thus combines the functions of amplifier, DAC and DSP for great flexibility.
Reference : 20416
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 24-04-2025.
Tinysine TSA7804C Module Amplificateur SPDIF TPA3116D2 DAC DSP 4x50W
Photo of TINYSINE TSA7804C
The Tynisine TSA7804C SPDIF amplifier module is a DSP amplifier module with 4 channels of 50W each. It's based on an SPDIFBee receiver module that converts the signal to I2S for transmission to the ADAU1701 DSP chip. This module thus combines the functions of amplifier, DAC and DSP for great flexibility. Thanks to its Class D architecture based on a TPA3116D2 amplifier chip, it can deliver 4x50W of output power continuously and simultaneously. The module's power supply range is 12V to 24V DC. It can be used to drive any 4Ω or 8Ω passive loudspeaker.
Tinysine TSA7804C: SPDIFBee input module
The TSA7804C features an SPDIFBee input module for converting an SPDIF signal into an I2S signal. It accepts sampling rates from PCM 16bit 44.1kHz to 24bit 96kHz, thanks to a BurrBrown DIR9001 chip, and conversion is performed by a Cirrus Logic CS8421 chip. I2S conversion offers a 16bit 48kHz sampling rate.
SPDIFBEE module
Tinysine TSA7804C: DSP ADAU1701
The DSP part of the module is based on an ADAU1701 chip, with a default program already loaded. With this basic program, you can adjust gain, bass, midrange and treble on each channel. Moreover, if you wish to program the module yourself to include your own functions, simply use TinySine's USBi Programmer (sold separately), which will allow you to include functions such as crossover, bass enhancement, multiband dynamic processing, delay compensation and more. Despite the presence of a port for connecting buttons, this function is not supported on this model. However, you will still have access to the volume control port, to which you can connect a TSA 1300 potentiometer (10K) (sold separately) to control volume.
Tinysine TSA7804C module overview
TINYSINE TSA7804C module overview
1Jack DC 12-24V DC power port
2Power supply via screw terminal 12-24V DC
3LED
4RCA input
5SPDIF input
5Control buttons
6External button port [NOT AVAILABLE]
7Switch
8Potentiometer
9DSP programming port
104x Screw terminal output
Product typeAmplifier / DAC / DSP module
Amplification chipTPA3116D2
Amplification typeClass D
SPDIF reception moduleSPDIFBee
DSP chipADAU1701
Inputs1x RCA input
1x SPDIF input
Outputs4x Amplified output on screw terminal block
Supported SPDIF sampling rates16bit, 44.1KHz, 48KHz, 88.2KHz, 96KHz
24bit, 44.1KHz, 48KHz, 88.2KHz, 96KHz
I2S sampling rate16bit 48kHz
Output power per channel4x50W (21V, 4Ω, THD+N 10%)
4x30W (24V, 4Ω, THD+N 10%)
4x18W (12V, 4Ω, THD+N 10%)
THD+N0.03% (@ 4Ω, 1W, 1kHz)
Bandwith20Hz-20kHz
Input impedance22kΩ
Minimum load impedance3.2Ω
Gain18dB (12V)
24dB (21V)
34dB (24V)
ProtectionOvervoltage, undervoltage, overload, thermal protection
Power supply12-24V DC
Dimensions13.5 x 9.2 x 3.4cm
Package1x Tinysine TSA7804C amplifier module
OutputScrew terminals
Channel4
Amplifier chipTPA3116D2
Power (W)50.0
TINYSINE TSA7804C SPDIF Amplifier Module TPA3116D2 DAC DSP 4x50W
The Tynisine TSA7804C SPDIF amplifier module is a DSP amplifier module with 4 channels of 50W each. It's based on an SPDIFBee receiver module...
