TINYSINE TSA8498B Amplifier Module Class D 2xTDA7498 Bluetooth aptX RCA 4x100W 6 Ohm
TinySine's TSA8498B modules are Class D amplifiers that deliver no less than 4x100W at 6Ω. They are also combined with an AudioB Plus module to offer Bluetooth reception supporting aptX, for more convenient use.
Reference : 12880
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 22-04-2025.
TinySine TSA8498B
TinySine TSA7499B
The TSA8498B module of TinySine is a Class D amplifier allowing to deliver not less than 4x100W under 6Ω. It is also combined with an AudioB Plus module to offer Bluetooth reception supporting aptX, for more convenient use. This amplifier is based on two TI TDA7498 chips. The TSA8498B can be powered by any power supply delivering 14-39V DC via a DC jack connector or via a screw terminal block. In addition, in order to protect the heating components from possible deterioration, a fan makes it possible to cool the assembly. This is activated only above 65°C in order to reduce the noise emitted.
This module has a Bluetooth input (via AudioB Plus) and an RCA input. The output is made directly on the screw terminals.
TinySine TSA7499B amplificateur class d 2x100W schema
Connection diagram
Amplifier chipTDA7498
Amplification typeClass D
Efficiency> 90%
Frequency response20Hz - 22kHz @ +-3dB
Output power4 x 100W @ THD=10% 6Ω
4 x 80W @ 8Ω
Input sensitivity1356mV @ 25.6dB
696mV @ 31.6dB
460mV @ 35.1db
341mV @ 37.6dB
Bluetooth version4.2
Supported protocolsaptX
aptX Low Latency
SBC
AAC
ProtectionsOver/Under-voltage
Over current protection
Over temperature protection
AlimentationJack DC 14-39V
Dimensions122 x 80 x 18.6mm
OutputScrew terminals
Channel2 (Stereo)
Power (W)100.0
TinySine's TSA8498B modules are Class D amplifiers that deliver no less than 4x100W at 6Ω. They are also combined with an AudioB...
