TINYSINE TSA8802D Amplifier Module
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a TPA3321 amplifier chip. DAC/DSP signal processing is carried out by an ADAU1701 chip, enabling it to support streams up to 24bit 96kHz via its Toslink optical input (TOSLINKBee receiver).
Reference : 19120
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 24-04-2025.
TINYSINE TSA8802D Amplifier Module TPA3221 DAC / DSP ADAU1701 24bit 192kHz 2x100W 4 ohm
Photo of TinySine TSA8802D amplifier module
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a TPA3321 amplifier chip. DAC/DSP signal processing is carried out by an ADAU1701 chip, enabling it to support streams up to 24bit 96kHz via its Toslink optical input (TOSLINKBee receiver). The TOSLINKBee receiver module converts the optical signal into an I2S signal, which is then processed by the ADAU1701 DAC/DSP chip before amplification. A stereo RCA input is also available on the module.
The ADAU1701 DSP chip features a preloaded program for adjusting gain, bass, midrange and treble in the Sigma Studio DSP program/interface. A debug port is available for Sigma Studio. To access advanced features, users can program the TSA8802D module via TinySine's USBi programmer. Advanced functions available include equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation and more.
The TSA8802D amplifier module is powered by 12V-30V DC and can drive passive loudspeakers with 2 ohm, 4 ohm or 8 ohm impedance.
TINYSINE TSA8802D amplifier module overview
TinySine TSA8802D amplification module overview diagram
1DC connector power supply port (12V-30V DC)
2Screw terminal block for power supply (12V-30V DC)
3Fan power connector
4Stereo RCA input
5Toslink input via TOSLINKBee module
6Gain DIP switch
7DAC/DSP chip ADAU1701
8Control buttons on PCB: Vol-/previous - Vol+/next - Play/pause
9DSP I/O control port
10Port for external buttons (not available)
11Port for external potentiometers
12Mute port
13Pre-out output
14USBi DSP update port
Please note that the external button port is not supported on the TSA8802D module.
TINYSINE TSA8802D: Ext POT port
The TinySine TSA8802D module features a dedicated port for connecting external potentiometers (5K - 20K) and controlling volume, bass, mid and treble. If you wish to use external potentiometers, TinySine offers a potentiometer KIT for this purpose, to be purchased separately.
  • ADC0 - Main volume
  • ADC1- Bass adjustment
  • ADC2 - Middle adjustment
  • ADC3 - Treble adjustment
Please note: to use external potentiometers, the module's DSP program must be updated to the version for external potentiometers, which can be found via our download tab.
Photo of TinySine Potentiometer KIT
TINYSINE TSA8802D: how do I load a new DSP program?
To load a new DSP program, you need a USBi JTAG DSP Sigma programmer. The default DSP program loaded on the module can automatically select either RCA line input or Toslink optical input, with priority given to the optical signal.
Photo of TinySine TSA8802D module gain adjustment via DIP switch
TINYSINE TSA8802D: gain adjustment via DIP switch
The TinySine amplifier module also features gain adjustment via DIP switch. The following settings are available:
  • 18dB : OFF / OFF / OFF / ON
  • 24dB : OFF / OFF / ON / OFF
  • 30dB : OFF / ON / OFF / OFF
  • 34dB : ON / OFF / OFF / OFF
Product typeAmplifier module with DSP
Amplification chipTPA3221
DAC/DSP chipADAU1701
Inputs1x RCA stereo
1x Optical Toslink (TOSLINK Bee receiver module)
OutputsStereo output on screw terminal
1x Pre-out output on PCB connector
Other connectors1x USBI DSP programmer port
1x Port for DSP control I/O
1x Port for external potentiometer
Buttons on PCBVol-/previous
Vol+/next
Play/Pause
Supported sample ratesSPDIF : 16bit/24bit 48KHz, 88.2KHz, 96KHz
I2S : 16bit 48KHz
Output power112W (RL= 3Ω, 10% THD+N, 24V DC)
105W (RL= 4Ω, 10% THD+N, 24V DC)
100W (RL= 3Ω, 1% THD+N, 24V DC)
88W (RL= 4Ω, 10% THD+N, 24V DC)
THD+N0.02% (1W)
SNR108dB (A-weighted, Gain = 18dB)
DNR109dB (A-weighted, Gain = 18dB)
Minimum load impedance3Ω(Min.)
4Ω(Typical)
Gain18dB
24dB
34dB
Efficiency90% (100W @ 4Ohm)
Input impedance48KΩ (gain 18dB)
24KΩ (gain 24dB)
12kΩ (gain 30dB)
7.7kΩ (gain 34dB)
ProtectionsOvervoltage, undervoltage, overcurrent, overtemperature
Power supply12V-30V DC
Dimensions350 x 920 x 350mm
Weight228g
Package1x TinySine TSA8802D Amplifier Module
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3321
Power (W)100.0
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a...
