TINYSINE TSA9840B Class D Mono Amplifier Module MAX98400A Bluetooth aptX TWS 20W 8 Ohm
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power of 20W. This module can then be used to power a passive speaker 8Ω.
Reference : 14111
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 25-04-2025.
TinySine TSA9840B
TinySine TSA9840B Module Amplificateur Mono Class D MAX98400A Bluetooth aptX TWS 20W 8Ω
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power of 20W. This module can then be used to power a passive speaker 8Ω. For more convenient use, the TSA9840B can be associated with volume controllers TSA1000 and TSA1020.
Le TSA9840B existe également en version stéréo.
Bluetooth TWS & aptX
The main feature of this amplifier module is the integration of an AudioB Plus module on it, allowing it to also become a Bluetooth 4.2 receiver. This AudioB Plus module supports aptX and TWS technologies.
The aptX protocol will provide a much more stable Bluetooth transmission and better signal synchronization. An asset for audio use and quality playback.
The TWS mode will allow you to stream an audio signal with 2 TSA9840B amplifiers at the same time. This way, you can enjoy excellent amplification in dual Mono mode.
The TSA9840B can automatically detect signals on the AUX / Line input. Bluetooth has a higher priority. When Bluetooth is disconnected or paused, the amplifier automatically switches to the AUX / Line input.
The TSA9840B and TSA1000 modules can be associated via the BVC port, allowing you to control the volume level on the AUX and Bluetooth inputs.
Operation of two TSA9840B modules in TWS mode.
  • S1 : Long press (3s) to activate pairing mode. Long press (6s) to reset the pairing information.
  • S1 + S2 : Press (1s) to activate the TWS slave mode
  • S1 + S3 : Press (1s) to activate the TWS master mode
  • S2 + S3 : Press (1s) to disable the TWS connection
Bluetooth pairing of the TSA9840
To pair your Bluetooth device with the TSA9840B, enable Bluetooth on your sending device. After a search, the module "TSA9840B" should appear in the list. Just choose it to start streaming.
Product typeAmplifier module
Number of channelMono (1)
ClassD
Amplification chipMAX98400A
Output power20W @ 8Ω
Inputs1x Jack 3.5mm
Bluetooth
Outputs1x Jack 3.5mm
Speaker terminal
Bluetooth moduleAudioB Plus
Bluetooth version4.2
Supported Bluetooth technologyaptX
TWS
Measurements
ParameterConditionMin.Typ.Max.
Supply voltageInferred from PSRR test10VDC-24VDC
Current limit-3.5A5A-
Bandwidth@ +/-3dB, 8Ω20Hz-22kHz
EfficiencyPO = 2x20W, MAX98400A, PVDD = 12V, RL = 8Ω-90%-
Minimum load impedance--8Ω-
Cutoff frequency-265kHz330kHz295kHz
Gain-9dB20.1dB29.8dB
Input sensitivity (RMS)--620mV-
Input impedance--22kΩ-
Output powerStereo, RL = 8Ω, THD+N 10%-22W-
Mono, RL = 4Ω, THD+N 10%-44W-
THD+NPOUT = 0.1W à POUT/2, fIN = 20Hz à 20kHz, RL = 8Ω-0.3%-
POUT/2, fIN = 1kHz, RL = 8Ω-0.03%-
Dimensions91 x 50 x 19mm
Supply voltage10-24VDC
Power connectorJack DC 5.5/2.5mm
InputJack 3.5mm
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipMAX98400A
Power (W)20.0
2 reviews
Excellent
Parfait. Résultat excellent avec un petit Hp Dayton 95-8.
This review has been posted for TINYSINE TSA9840B Class D Mono Amplifier Module MAX98400A Bluetooth aptX TWS 20W 8 Ohm
Ampli bluetooth aptX
Très bon produit, le codec aptX est un vrai plus. L'objet est compact et intuitif. La marque propose plusieurs accessoires disponibles pour ce type d'amplificateur, c'est un plus.
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power...
