TINYSINE TSA9840B Class D Stereo Amplifier Module MAX98400A Bluetooth aptX TWS 2x20W 8 Ohm
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, delivering 2x20W power. This module can then be used to power two 8Ω passive speakers.
Reference : 12879
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 22-04-2025.
TinySine TSA9840B
Class D Amplifier Module 2x20W MAX98400A Bluetooth aptX TWS
TinySine TSA9840B
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, delivering 2x20W power. This module can then be used to power two 8Ω passive speakers. For a more practical use, the TSA9840B can be associated with volume controllers TSA1000 and TSA1020.
The TSA9840B can automatically detect audio input. Bluetooth has a higher priority. When Bluetooth is disconnected or paused, the amplifier switches directly to the Line in.
BVC = Bluetotoh Volum Control (Contrôle du volume de Bluetotoh)
Bluetooth TWS & aptX
The main feature of this amplifier module is the integration of an AudioB Plus module, allowing it to also become a Bluetooth 4.2 receiver. This AudioB Plus module supports aptX and TWS technology.
The aptX protocol will provide a much more stable Bluetooth transmission and better signal synchronization. An asset for audio use and quality playback.
The TWS mode will allow you to stream an audio signal to 2 TSA9840B amplifiers at the same time. So you can enjoy excellent amplification in Dual Mono mode.
Pairing
To pair your Bluetooth device with the TSA9840B, enable Bluetooth on your transmitting device. After a search, the module "TSA9840B" should appear in the list. Just choose it to start streaming.
Amplifier chipMAX98400A
PowerStereo : 2x22W 8Ω THD+N = 10%
Mono : 1x44W 4Ω THD+N = 10%
THD+NP OUT=0.1W à P OUT/2, fIN = 20Hz - 20KHz, 8Ω : 0.03%
P OUT/2, fIN = 1kHz, 8Ω
Frequency response20Hz - 22kHz @ 8Ω
EfficiencyPO = 2x20W, PVDD = 12V, RL = 8Ω : 90%
Input sensitivity (RMS)620mV
Input impedance22KΩ
Bluetooth version4.2
Bluetooth protocolsaptX
aotX Low Latency
SBR
AAC
TWS supportYes
ProtectionsThermal and overload
Power supplyDC 10V - 24V - Jack DC 5.5/2.5mm (not included)
Dimensions91 x 50 x19mm
InputJack 3.5mm
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Power (W)20.0
2 reviews
Très bon produit.
Parfaitement adapté à la réalisation d'enceintes Bluetooth. Les 2x20w sont bien réels.
This review has been posted for TINYSINE TSA9840B Class D Stereo Amplifier Module MAX98400A Bluetooth aptX TWS 2x20W 8 Ohm
Fonctionnement impécable
Bon petit ampli avec récepteur Bluetooth, bonne qualité de son , à faire fonctionner avec des enceintes de bon rendement pour avoir la puissance , prévoir alimentation de 24 v. Fonctionne sans autre carte cependant c'est l'appareil émetteur qui assure le réglage de volume, . Connectique HP par bornier, entrée jack, Alimentation 9-24 v par prise ou par bornier.
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, delivering 2x20W power. This module can then be...
