TPA3116D2 Amplifier Module Class D 2x50W + 100W Volume Control
Reference : 13068
18,90 €tax incl.
15,75 € tax excl.
TPS3116D2 Amplifier
Amplifier module 2.1 Class D 2x50W + 100W with Volume Control
Amplificateur TPS3116D2
This Class D amplifier module based on two TPA3116D2 chips will allow you to manufacture a complete, simple and efficient device. It is a 2.1 module, capable of delivering 50W in stereo but also 100W additional for the use of a subwoofer. The module has independent volume controls for satellites and subwoofer, as well as an overall volume.
TPS3116D2 TPA3116
Dual TPA3116D2 chip for 2.1 amplifier
The TPS3116D2 amplifier module therefore includes a pair of TPA3116D2 amplification chips. These allow you to deliver 2x50W for your satellite speakers, but also 100W more, dedicated to powering a subwoofer for a boost in low frequencies. In addition, the architecture of the amplifier, in Class D, makes it possible to benefit from a very good output. As a result, it loses less energy, which gives it a good power reserve.
Control the volume of each output
The TPS3116D2 has a series of 3 rotary knobs. These will allow you to adjust the overall volume (master), but also, completely independently, the volume of the satellites and the volume of the subwoofer. Perfect to balance your system and have an accurate restitution.
TPS3116D2 Contrôle de volume
TPA3116D2 module amplificateur Class D 2x50W + 100W avec filtres et contrôles de volume
Amplifier chip2x TPA3116D2
Output power2x 50W + 100W @ 8 Ohm
Minimum impedance for each channel4 Ohm
SNR100dB
Frequency response14Hz - 100kHz
InputsStereo Jack 3.5mm
3 pins connector
Output6 screws terminal
Power supply12V DC Jack DC 5.5x2.1mm
Dimensions10 x 3 x 7mm
InputJack 6.35mm
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3116D2
Power (W)50.0
Power (W)100.0
Ampli fonctionnel
Bonjour.
Module monté dans un caisson de basses JVC à la place de l'ampli d'origine, alimenté par une alimentation d'ordinateur portable de 110W réglée sur 18V. Débite sur 3 haut-parleurs de 4 ohms.
Le son est très bon, très “propre”, assez puissant pour mes synthés !
Cordialement.
This review has been posted for TPA3116D2 Amplifier Module Class D 2x50W + 100W Volume Control
