WONDOM AA-AB31413 Mono Class D T-Amp Amplifier Module 1500W 2 Ohm
This Class D amplifier module Wondom AA-AB31413 is capable of delivering no less than 1500W at 2Ω with a high efficiency of 90% as well as a high level of detail and beautiful dynamics.
Reference : 14365
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 25-04-2025.
Wondom AA-AB31413
Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω
This Class D amplifier module Wondom AA-AB31413 is capable of delivering no less than 1500W at 2Ω with a high efficiency of 90% as well as a high level of detail and beautiful dynamics. The module is based on a Sure Electronics T-Amp chip, which reduces the level of distortion considerably. The heat-generating components are concealed under a heat sink and a fan, allowing the heat to be dissipated efficiently to protect the hardware. In addition, protections against overload, over/under voltage and excessive temperature are built into this Wondom AA-AB31413.
Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω
Product typeAmplifier module
Amplification classD
ChannelMono (1)
Amplification chipT-Amp
Power1500W @ 2Ω, 84VDC, THD+N = 10%
Minimum load impedance2Ω
Efficiency90%
Switching frequency500kHz
Input sensitivity1.2Vrms @ 1500W, 2Ω, 1kHz
SNR100dB @ 400W, 4Ω, A-Weighting
THD+N0.04% @ 10W, 4Ω, 1kHz
0.08% @ 100W, 4Ω, 1kHz
Input impedance10kΩ
Output noise level450uV (@ A-Weighting)
DC Offset50mV
Gain33dB @ 2Ω, 1kHz
BTL Support
Power supply48-120V
Dimensions152.4 x 114.3mm
Weight884g
Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω Wondom AA-AB31413 Module Amplificateur T-Amp Class D Mono 1500W 2Ω
InputJack 3.5mm
OutputScrew terminals
Channel1 (Mono)
Amplifier chipN/A
Power (W)1500.0
This Class D amplifier module Wondom AA-AB31413 is capable of delivering no less than 1500W at 2Ω with a high efficiency of 90% as well as a high...
