Wondom's AIPO2X8 amplifier module is a versatile and robust solution for anyone wishing to build an audio installation. Its Texas Instrument TPA3110 amplifier chip enables this module to offer 2x8W or 1x16W amplification, while guaranteeing a signal-to-noise ratio of 103dB for crystal-clear sound reproduction. Its robust construction makes it suitable for use in extreme environments, with an operating temperature range from -20 to 65°C.
The AIPO2X8 is based on a Texas Instrument TPA3110 chip offering 8W output power in stereo or 16W in mono. Furthermore, this chip is equipped with EMI suppression technology and SpeakerGuard protection circuits, including an adjustable power limiter and DC current detection.
The AIPO2X8 supports flexible output configurations. Thanks to its customizable output mode, the AIPO2X8 lets you switch between 8W dynamic stereo and 16W mono configurations, making it an ideal choice for a wide variety of applications.
The AIPO2X8 amplifier module has been designed to be as user-friendly as possible. Integrated switches directly on the board let you easily adjust gain levels and output modes. For even greater flexibility, the AIPO2X8 also includes a power-on control port. This intuitive control system lets you tailor amplifier configurations to your specific requirements without having to perform complex operations.
The AIPOX2 also stands out for its robust construction. It has been designed to operate over a temperature range from -20° to 65°C, enabling it to function in the most extreme environments. Furthermore, the module features protection against current overload, overheating and polarity reversal. All these qualities, combined with excellent heat dissipation, make this a module with a long life and stable performance.
1 | Powered by external battery |
2 | Alimentation 10V-24V DC |
3 | Fault LED |
4 | Jack 3.5mm line input |
5 | JST PH-POS line input |
6 | Output mode switch |
7 | Speaker output |
8 | Power LED |
9 | Output mode LED |
10 | Gain mode switch |
11 | Control port |
Product type | Module amplificateur |
Inputs | Entrée ligne Jack 3.5mm Entrée ligne JST PH 5-POS |
Output | 1x Haut-parleur Molex |
Output power | 2x8W @ 4Ω 1x16W @ 4Ω |
Gain | Low gain : 18.6dB High gain : 24.6dB |
Total harmonic distortion (THD) | Low gain : 0.029% High gain : 0.035% |
Signal-to-noise ratio (SNR) | Low gain : 103dB High gain : 101dB |
Output noise level | Low gain : 58μV High gain : 78μV |
Frequency response | 20Hz-20kHz (±3dB) |
Load impedance | 2Ω-8Ω |
Power supply voltage | 10V-24V DC |
Dimensions | 76.2 x 50.8mm |
Mounting holes | 66.04 x 40.64mm 69.84 x 44.44mm |
Package | 1x Wondom AIPO2X8 1x 50cm speaker cable 1x 50cm power cable |
Input | Jack 3.5mm |
Input | PH 2.0mm |
Output | Molex |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3110 |
Power (W) | 8.0 |
Power (W) | 16 |
