WONDOM AA-AB32192 Amplifier Module Class D TAS5630 2x300W 4 Ohm
The Wondom AA-AB32192 is a Class D stereo amplifier module based on a TAS5630B amplifier chip and capable of delivering a power of 2x300W under 4 Ohm (THD+N 10%). This amplification chip also allows to reach a very high efficiency, up to 96%.
Reference : 14611
62,90 €tax incl.
52,42 € tax excl.
Shipping date: 23-04-2025.
Wondom AA-AB32192
Amplifier Module Class D TAS5630 2x300W 4Ω
Wondom AA-AB32192 Module Amplificateur Class D TAS5630 2x300W 4Ω
The Wondom AA-AB32192 is a Class D stereo amplifier module based on a TAS5630B amplifier chip and capable of delivering a power of 2x300W under 4 Ohm (THD+N 10%). This amplification chip also allows to reach a very high efficiency, up to 96%, allowing to accompany the most demanding loudspeakers, while offering excellent performances, especially with a low THD+N and a high SNR.
The amplification stage of the module is concealed by a low-noise fan, which activates only at a defined temperature (45°C), thus effectively dissipating the heat emitted by the circuit components.
Product typeAmplifier module
Amplification typeClass D
Amplification chipTAS5630B
Entrées1x Stereo RCA
Contacts to solder
SortiesSpeaker terminal
Power2x300W @ 4Ω, 48VDC, THD+N 10%
2x246W @ 4Ω, 48VDC, THD+N 1%
Channel2 (Stereo)
ProtectionsOver current
Heat protection
Measurements
ParameterConditionsMin.Typ.Max.
Supply voltage-25VDC48VDC-
Max current.600W @ 4Ω-13.5A-
Efficiency300W @ 4Ω91%-96%
Min. load impedance--3.5Ω-
Switching frequencySD Floating-400kHz-
Fan activation temperature--50°C-
Gain-28dB30dB32dB
Input sensitivity (RMS)@ 4Ω, 300W, 1kHz-1.2V-
Input impedance--10kΩ-
Output power@ 4Ω THD+N 1%-246W-
@ 4Ω THD+N 10%-300W-
Frequency response@ ±3dB, 4Ω20Hz-20kHz
THD@ 4Ω, 1W, 1kHz-0.07%-
@ 4Ω, 10W, 1kHz-0.028%-
Output noise lvelA-Weighting, input connected to GND-250µV-
SNR246W @ 4Ω THD+N 1%-89dB-
Dimensions121.9 x 91.4 x 38.9mm
Weight511g
Wondom AA-AB32192 Module Amplificateur Class D TAS5630 2x300W 4Ω Wondom AA-AB32192 Module Amplificateur Class D TAS5630 2x300W 4Ω Wondom AA-AB32192 Module Amplificateur Class D TAS5630 2x300W 4Ω Wondom AA-AB32192 Module Amplificateur Class D TAS5630 2x300W 4Ω
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTAS5630
Power (W)300.0
The Wondom AA-AB32192 is a Class D stereo amplifier module based on a TAS5630B amplifier chip and capable of delivering a power of 2x300W under 4...
