WONDOM AA-AB32231 Audio Amplifier Board TPA3110 2 x 8 Watts 4 Ohms Class D
This small Class D AB32231 amplifier module from Wondom is based on a TPA3110 amplifier chip. It is capable of operating in stereo mode by delivering 2x8W and in mono mode by delivering 1x16W.
Reference : 10050
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 23-04-2025.
WONDOM AB32231
Amplifier module TPA3110 Class D 2x8W 4 Ohm
Wondom AB32231 Module amplificateur TPA3110 Class D 2x8W 4 Ohm
A compact but really complete module
The compactness of this module and the power offered will allow you to create small, high-performance on-board systems. In addition, it offers many features and modes of use, allowing it to adapt to the great majority; needs (find explanations in sections "Mode and input method", "Mode Stéo" and "Mono Mode" on this page).
Wondom AB32231 TPA3110
TPA3110, a high-performance chip ideal for small systems
The TPA3110D2 amplifier chip from TI integrated in this AB32231 is ideal for designing small amplifiers. Indeed, this one makes it possible to deliver a sufficient power for this type of use and in a clean way. It uses an advanced EMI interference suppression system to limit noise interference.
In addition, this chip is capable of combining with stereo speakers with impedance down to 4 Ohm. Its high efficiency allows it to do without a heatsink and thus save space.
Electrical characteristics in stereo mode, 8 Ohm
ParameterConditionsMin.Typ.Max.Unit
Number of channels--2-
Operating voltage-81219V
Impedance-4.88-Ohm
Nominal power requirement8W @ 1kHZ 8 Ohm-18-W
Output power1kHz, THD+N = 0.1%-8-W
Switching frequency--310-kHz
Efficiency16W @ 4 Ohm-90-%
Audio characteristics in stereo mode, 8 Ohm
SNRSE. 8W @ 8Ohm, THD+N=1%, A-Weighting-100-dB
DIFF. 8W @ 8Ohm, THD+N=1%, A- Weighting-98-dB
THD+NSE. 5W @8 Ohm, 1kHz-0.02-%
DIFF. 5W @ 8Ohm, 1kHz-0.02-%
Output noise levelSE. A-Weighting, Entrée connectée à GND-80-µV
DIFF. A-Weighting, Entrée connectée à GND-80-µV
Frequency response@ 4 Ohm, 1kHz, +/-3dB20-20kHz
Amp gainSE. @ 8 Ohm, 1kHz-26-dB
DIFF. @ 8 Ohm, 1kHz-12-dB
Input impedanceSE.-30-Kohm
DIFF.-45-Kohm
Electrical characteristics in mono mode, 4 Ohm
Number of channels--1-
Impedance-3.24-Ohm
Nominal power requirement16W @ 1kHZ 4 Ohm-19-W
Output power1kHz, THD+N = 0.1%-16-W
Audio characteristics in mono mode, 4 Ohm
SNRSE. 8W @ 4 Ohm, THD+N=1%, A-Weighting-95-dB
DIFF. 8W @ 4 Ohm, THD+N=1%, A-Weighting-97-dB
THD+NSE. 5W @ 4 Ohm, 1kHz-0.1-%
DIFF. 5W @ 4 Ohm, 1kHz-0.06-%
Input sensitivitySE. 16W @ 4 Ohm, 1kHz-400-mV
DIFF. 16W @ 4 Ohm, 1kHz-2k-mV
Amp gainSE. @ 4 Ohm, 1kHz-26-dB
DIFF. @ 4 Ohm, 1kHz-12-dB
DIFF.-45-Kohm
Dimensions
Choose input mode and method
ModeSW1SW2 : 3, 4
StereoBOFF
MonoAON
Input methodSW2 : 1, 2
Singled-EndedON
DifferentialOFF
Mode Stéréo
Wondom AB32231 Mode stéréoWondom AB32231 Mode stéréo
Mode Mono
Wondom AB32231 Mode mono
Power connector :
  • J3 : DC 8-19V - Jack DC 5.5/2.1mm
  • J1 : RJ128
Speaker output connector :
  • J5, J7 : RJ128
Audio input connector :
  • J8 : Used for single-ended input terminal block in mono mode
  • J6 : Used for differential input in mono mode
IDDescription
J5Negative polarity of mono output
J7Positive polarity of mono output
Mute mode parameter :
  • J2 : RJ128
Performances graphs
InputScrew terminals
InputJack 3.5mm
InputMolex
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3110
Power (W)8.0
Très bon module
Ce petit module est étonnant dans sa tenu du grave sur de petites enceintes les valeureux 2x8 Watts sont très véloces et dynamique.
This review has been posted for WONDOM AA-AB32231 Audio Amplifier Board TPA3110 2 x 8 Watts 4 Ohms Class D
This small Class D AB32231 amplifier module from Wondom is based on a TPA3110 amplifier chip. It is capable of operating in stereo mode by...
