Amplifier Module FDA TAS5754 2x30W 4 Ohm 24bit 192kHz
The Wondom AA-AB32256 module is a high-performance FDA amplifier with an integrated audio processor. It is based on an amplifier chip TI TAS5754, allowing it to develop a power of 2x30W under 4Ω (THD 10%) with a high efficiency. The AA-AB32256 has an I2S input and supports file playback up to 24bit 192kHz, allowing you to enjoy your music in high quality. Its smart design ensures low noise, high SNR and THD+N of only 0.6%. In addition to the speaker output on terminals, the module offers a DAC output that does not pass through the amplifier stage, as well as an amplified analog output on PH2.0 connectors. Finally, the module can be associated with an ON/OFF button and a volume control (sold separately).
Spécifications | |
Product type | Amplification module |
Inputs | I2S Digital 3 pins |
Output | Speaker terminals DAC output without amplification Analog output with amplification |
Amplification chip | TAS5754 |
Power | 2x 30W @ 4Ω, 19VDC, THD+N 10% |
Supported sampling rates | Up to 24bit 192kHz |
Measurements | ||||
Parameter | Conditions | Min | Typ | Max |
Power supply | J2/J4 (Power adapter/Power supply) | 10VDC | 19VDC | 24VDC |
J3 (Battery module) | 14VDC | - | 21VDC | |
Max. current | 30W @ 4Ω | - | 3A | - |
Efficiency | 30W @ 4Ω | - | 90% | - |
Min. load impedance | - | - | 4Ω | - |
Switching frequency | SD floating, 8 x Fs, LRCK = 48kHz | - | 384kHz | - |
Gain | Can be adjusted up to -100dB with the Wondom Volume Control Module | - | 28dB | - |
Power | @ 4Ω, THD+N 10% | - | 30W | - |
Frequency response | @ ±3dB, 4Ω | 20Hz | - | 20kHz |
THD | @ 4Ω, 1W, 1kHz | - | 0.05% | - |
Output noise level | A-Weighting | - | 80µV | - |
SNR | THD+N < 1%, A-Weighting | - | 102dB | - |
Dimensions | 91.4 x 68.6mm |
Weight | 58g |
Input | I2S |
Output | Speaker terminal |
Output | PH 2.0mm |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TAS5754 |
Power (W) | 30.0 |
