Enfin testé ce weekend sur des b2 d&b, ça s'est très bien comporté, alimenté par 6 batteries 12v en série, un bonheur. On verra dans le temps mais c'est du sérieux.
- Class D / 2x1200W
This Class D Sure amplifier has the particularity of offering a high power output. It is therefore suitable for Hifi but also for specific uses such as a cinema room, the amplification of musical instruments or even systems for recording studios.
The HPA consists of a series of 12 high-power amplifiers powered by a single power supply. All of the amplifiers are controlled by a Class-T modulator, providing both warm and powerful sound. This amplifier includes features such as signal loops and high-quality components to provide exceptional sound performanceonal
The input sensitivity of the amplifier series can be adjusted quite broadly. This allows the system to adapt to various types of sources. It can accept as input a maximum power of 10Vrms and impedances of 1.5 to 16 Ohms.
With high efficiency up to 93% and very low power consumption, HPA delivers high power efficiency. Its design has also been designed to effectively dissipate residual heat with a fan controlled by a probe. This allows the amplifier chips to operate stably by delivering from 500W to 2000W.
The series of amplifiers is integrated in accordance with the principle of durability. Thus, they are tested both with a dummy load resistor of 1kW and a 2550W air conditioning system in parallel. These tests ensure that each amplifier can withstand the harshest uses, and therefore your audio uses.
The module has a signal detection system, allowing the system to automatically change channels, in order to improve the user experience and simplify the daily use of the product.
The amplifiers are equipped with four protection systems to avoid material damage: overvoltage, overcurrent, excessive temperatures, anti-inversion high voltage.
Sure selects soigneusits suppliers in order to equip its products with the best possible components in terms of performance and durability.
Input | RCA |
Output | Screw terminals |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 1200.0 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
reginald B.
