WONDOM AA-AB32281 Class D Stereo Amplifier Board T-Amp 2x130W 3 Ohm
The Wondom AA-AB32281 is a stereo amplifier module capable of delivering 2x128w of power at 3Ω. Featuring a Class D architecture based on Sure Electronics' T-Amp technology, it achieves a very high efficiency of 91% and excellent sound quality with very low distortion and noise level. Its SNR is measured at 94dB and its THD+N at 0.004% (@ 3Ω, 1W, 1kHz).
Reference : 15606
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 18-04-2025.
Wondom AA-AB32281
Wondom AA-AB32281 Module amplificateur stéréo Class D 2x128w
The amplifier is also topped by a fan and radiator to effectively dissipate the heat emitted by the components. It also benefits from a complete protection system, against overheating or overcurrent.
Product typeAmplifier board
ChannelsStereo (2)
Output power2x 200W @ 3Ω, 36VDC, THD+N 10%
2x 128W @ 3Ω, 36VDC, THD+N 1%
Input1x Stereo RCA
Sortie1x Speaker output on screw terminals
ProtectionsOver-currents
Over heating
Measurements
ParameterConditionsMin.Typ.Max.
Max current400W @ 3Ω-12.6A-
Efficiency200W @ 3Ω86%-91%
Min. load impedance--3Ω-
Switching frequencySD Floating-730kHz-
Fan activation temperature--50°C-
Gain-24dB26dB28dB
Input sensitivity3Ω, 200W, 1kHz-740mVrms-
Input impedance--33kΩ-
Output power3Ω, THD+N 1%-128W-
3Ω, THD+N 10%-200W-
Bandwidth @ ±3dB3Ω20Hz-20kHz
THD3Ω, 1W, 1kHz-0.004%-
3Ω, 10W, 1kHz-0.02%-
Output noise levelA-Weighting, input connected to GND-188µV-
SNR128W, 3Ω, THD+N 1%-94dB-
Supply voltage15-36V
Dimensions121.92 x 91.44mm
Weight518g
Wondom AA-AB32281 Module amplificateur stéréo Class D 2x128w Wondom AA-AB32281 Module amplificateur stéréo Class D 2x128w Wondom AA-AB32281 Module amplificateur stéréo Class D 2x128w Wondom AA-AB32281 Module amplificateur stéréo Class D 2x128w
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipT-Amp
Power (W)130.0
The Wondom AA-AB32281 is a stereo amplifier module capable of delivering 2x128w of power at 3Ω. Featuring a Class D architecture based on...
