WONDOM AA-AB32433 Amplifier Module Class D T-Amp 2x 750W 4 Ohm
This Class D Wondom AA-AB32433 stereo amplifier is capable, thanks to the T-Amp technology, of developing a consistent power of 2x750W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
Reference : 14101
159,00 €tax incl.
132,50 € tax excl.
Wondom AA-AB32433
Amplifier Class D T-Amp 2x 750W 4Ω
Wondom AA-AB32433 Amplificateur Class D T-Amp 2x 750W 4Ω
This Class D Wondom AA-AB32433 stereo amplifier is capable, thanks to the T-Amp technology, of developing a consistent power of 2x750W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models. In addition, T-Amp technology ensures high quality sound reproduction, marked by a beautiful transparency and richness of the audio message.
In addition, the amplifier incorporates features such as signal detection, flexible input sensitivity and low power consumption. To effectively dissipate the heat released by the system, the PCB is topped by a heat sink and a low-noise fan. This cooling system ensures greater durability for the product. In addition, the AA-AB35281 has over/under voltage, overload and temperature protections that are too high.
Product typeAmplifier
ClassD
Amplification moduleT-Amp
Power2x 750W @ 4Ω, 72VDC, THD+N 10%
Input1x Stereo RCA
Load impedance2-6Ω
Efficiency90%
Required nominal power1800W @ 72V
Switching frequency550kHz @ 72V
Under voltage protection40V
Input sensitivity1.3V (@ 750W, 4Ω, 1kHz)
SNR99dB (@ 450W 4Ω, THD+N 1%, A-Weighting)
THD+N0.05% (@ 1W 4Ω, 1kHz)
0.03% (@ 10W 4Ω, 1kHz)
Input impedance10kΩ
Output noise level450µV (A-Weighting, input connected to GND)
DC Offset30mV
Crosstalk separation-80dB (@ 10W 4Ω, 1kHz)
Gain34dB (@ 4Ω, 1kHz)
Dimensions152.4 x 114.3mm
Power supply48-90VDC
Weight825g (+/-10%)
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)750
This Class D Wondom AA-AB32433 stereo amplifier is capable, thanks to the T-Amp technology, of developing a consistent power of 2x750W at 4Ω with...
