WONDOM AA-AB32516 Amplifier Module Class D T-Amp 2x 500W 4 Ohm
This Class D Wondom AA-AB32516 stereo amplifier is capable, thanks to T-Amp technology, of developing a consistent power of 2x500W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
Reference : 14102
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 22-04-2025.
Wondom AA-AB32516
Amplifier Class D T-Amp 2x 500W 4Ω
Wondom AA-AB32516 Amplificateur Class D T-Amp 2x 500W 4Ω
This Class D Wondom AA-AB32516 stereo amplifier is capable, thanks to T-Amp technology, of developing a consistent power of 2x500W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models. In addition, T-Amp technology ensures high quality sound reproduction, marked by a beautiful transparency and richness of the audio message.
In addition, the amplifier incorporates features such as signal detection, flexible input sensitivity and low power consumption. To effectively dissipate the heat released by the system, the PCB is topped by a heat sink and a low-noise fan. This cooling system ensures greater durability for the product. In addition, the AA-AB32516 has over/under voltage, overload and over temperature protection.
Product typeAmplifier
ClassD
Amplification moduleT-Amp
Power2x 500W @ 4Ω, 60VDC, THD+N 10%
Input1x Stereo RCA
Load impedance2-6Ω
Efficiency90%
Required nominal power1100W @ 60V
Switching frequency600kHz @ 60V
Under voltage protection40V
Input sensitivity1.1V (@ 500W, 4Ω, 1kHz)
SNR99dB (@ 300W 4Ω, THD+N 1%, A-Weighting)
THD+N0.05% (@ 1W 4Ω, 1kHz)
0.03% (@ 10W 4Ω, 1kHz)
Input impedance10kΩ
Output noise level450µV (A-Weighting, input connected to GND)
DC Offset30mV
Crosstalk separation-80dB (@ 10W 4Ω, 1kHz)
Gain33dB (@ 4Ω, 60V)
Dimensions152.4 x 114.3mm
Power supply48-72VDC
Weight800g (+/-10%)
Wondom AA-AB32516 Module Amplificateur Class D T-Amp 2x 500W 4 Ohm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)500.0
This Class D Wondom AA-AB32516 stereo amplifier is capable, thanks to T-Amp technology, of developing a consistent power of 2x500W at 4Ω with an...
