WONDOM AA-AB35281 T-Amp Class D Amplifier Module 3x200W 3 Ohm
This Wondom AA-AB35281 multi-channel amplifier uses T-Amp technology allowing it to deliver a consistent power of 3x200W under 3Ω with a high efficiency of 94%. This energy reserve allows it to be associated with a wide range of speakers, including demanding models.
Reference : 13722
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 25-04-2025.
Wondom AA-AB35281
Wondom AA-AB35281 Module Amplificateur Class D T-Amp 3x200W 3Ω
This Wondom AA-AB35281 multi-channel amplifier uses T-Amp technology allowing it to deliver a consistent power of 3x200W under 3Ω with a high efficiency of 94%. This energy reserve allows it to be associated with a wide range of speakers, including demanding models. In addition, T-Amp technology ensures a high quality sound reproduction, marked by a beautiful transparency and richness of the audio message.
To effectively dissipate the heat released by the system, the PCB is topped by a low-noise fan and a heat sink. This cooling system ensures greater durability for the product. In addition, the AA-AB35281 has over/under voltage, overload and overtemperature protection.
Wondom AA-AB35281 Module Amplificateur Class D T-Amp 3x200W 3ΩWondom AA-AB35281 Module Amplificateur Class D T-Amp 3x200W 3Ω
Product typeAmplifier module
Channels number3
Power3x200W @ 3 Ohm 36VDC THD+N 10%
3x160W @ 3 Ohm 36VDC THD+N 1%
Amplification typeT-Amp
ClassClass D
PBTL SupportYes
Inputs3x Single Ended RCA
Outputs3x Speaker screw terminals
ProtectionsOver/Under voltage
Overload
Thermal protection
Measurements
ParameterConditionsMinTypMax
Output power@ 3Ω THD+N 1%-160W-
@ 3Ω THD+N 10%-200W-
Supply voltage-24VDC36VDC-
Max current600W @ 3Ω-18.1A-
Efficiency200W @ 3Ω89%-94%
Minimum impedance--2.5Ω-
Switching frequency--711kHz-
Fan activation temperature--50°C-
Gain-28.5dB30.5dB32.5dB
Input sensitivity (RMS)@ 3Ω, 200W, 1kHz-722mV-
Input impedance--33kΩ-
Frequency response (@ ±3dB)@ 3Ω20Hz-20kHz
THD@ 3Ω, 1W, 1kHz-0.004%-
@ 3Ω, 10W, 1kHz-0.006%-
Output noise level--223µV-
SNR160W @ 3Ω THD+N 1%-93dB-
Dimensions152.4 x 114.3mm x 37.59mm
Weight680g
OutputSpeaker terminal
Channel3
Amplifier chipT-Amp
Power (W)200.0
This Wondom AA-AB35281 multi-channel amplifier uses T-Amp technology allowing it to deliver a consistent power of 3x200W under 3Ω with a high...
