WONDOM AA-BK31271 BRICK DBKL3 Amplifier Module
Wondom's Brick DBKL3 amplifier module offers impressive 900W mono amplification at 2Ω, based on discrete components. It was developed to meet a wide range of requirements for a wide variety of DIY applications. The module has a wide load impedance range and is equipped with numerous protections, making it both a flexible and reliable amplifier.
Reference : 20382
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 25-04-2025.
Wondom AA-BK31271 Brick DBKL3 Class D Amplifier Module Mono 900W 2Ω
Wondom Brick DBKL3 : Front view
Wondom Brick DBKL3: A powerful module
The Brick DBKL3 is the result of meticulous design by Wondom. This module has benefited from dedicated PCB design and careful component selection to produce a sound that's both powerful and clean. The result is an output power of 900W into 2Ω, with a signal-to-noise ratio of 96dB and a harmonic distortion of just 0.02%.
Wondom Brick DBKL3 : SNR and THD
Wondom Brick DBKL3 : Two input modes
Wondom Brick DBKL3: Multiple input modes
The Brick DBKL3 supports a Single-ended input for compatibility with the vast majority of equipment. Moreover, this module also supports a differential input, to considerably reduce noise in the final rendering. Both input methods are optional, and can be selected via a switch on the back of the board.
Wondom Brick DBKL3: Gain adjustment
In order to adapt to all possible uses of this module, it has a gain setting that lets you choose between a low gain of 33dB or a high gain of 37dB. Like the input method setting, the gain setting is available via a switch on the back of the board.
Wondom Brick DBKL3: Extended load impedance
The Brick DBKL3 features highly flexible load impedance characteristics for optimized frequency response. It has been laboratory-tested with capacitive, inductive and resistive loads to ensure stability and performance. Thanks to its low output impedance, this audio amplifier board supports a wide range of loads from 1.5Ω to 16Ω without being influenced by the load characteristics of the drivers.
Wondom Brick DBKL3 : Load impedance range
Wondom Brick DBKL3 : Consumption
Wondom Brick DBKL3: Automatic standby mode
This high-power amplifier module features a signal level sensor system for optimized power consumption. It continuously measures the input signal and has a predefined signal voltage threshold. When no signal is detected (voltage below threshold) for a certain period of time, the amplifier board automatically switches to standby mode, drastically reducing power consumption. Standby power consumption when no signal is detected is just 1.2 W. As soon as a signal is detected, the amplifier immediately returns to operation.
Wondom Brick DBKL3: Reliability
Aware of the wide variety of uses to which the Brick DBKL3 will be put, Wondom has taken every measure to ensure exemplary robustness. For example, this module is equipped with protection against current overload, overheating and reverse polarity. Furthermore, this module has also undergone HASS and HALT testing during its design, ensuring long-term reliability.
Wondom Brick DBKL3 : Protections
Wondom Brick DBKL3 : Interface
Wondom Brick DBKL3: Simple integration
For the simplest integration, the Brick DBKL3 comes with an interface including RCA and XLR inputs and a screw terminal block, allowing you to connect easily.
Product typeAmplifier Module
Inputs1x Single-ended RCA
1x Balanced XLR
Output1x Screw terminal block
Output power900W @ 2Ω 1% THD+N
1200W @ 2Ω 10% THD+N
Efficiency90%
Load impedance1.5Ω - 16Ω
GainLow gain: 33dB
High gain: 37dB
Single-ended input
Input sensitivityLow gain: 1.1V
High gain: 0.65Vrms
Signal-to-noise ratio (SNR)Low gain: 96dB
High gain: 95dB
Total harmonic distortion more noise (THD+N)10W@4Ohm, 1kHz: 0.02%
100W@4Ohm, 1kHz: 0.08%
Input impedance15kΩ
Output noise level400μV
Differential input
Input sensitivityLow gain: 1Vrms
High gain: 0.7Vrms
Signal-to-noise ratio (SNR)Low gain: 95dB
High gain: 94dB
Total harmonic distortion more noise (THD+N)10W @ 4Ohm, 1kHz: 0.03%
100W @ 4Ohm, 1kHz: 0.08%
Input impedance15kΩ
Output noise level350μV
Power supply voltage48V-72V
Dimensions99.06 x 90.06mm
Mounting holes88.9 x 88.9mm
Weight660g
Package1x Wondom Brick DBKL3
1x Interface board
1x PH-6pos cable for interface card 20cm
1x TE cable for driver 50cm
1x Molex cable for power supply 50cm
InputXLR
OutputScrew terminals
Channel1 (Mono)
Amplifier chipTransistors
Power (W)900.0
WONDOM AA-BK31271 BRICK DBKL3 Class D Amplifier Module Mono 900W 2 Ohm
Wondom's Brick DBKL3 amplifier module offers impressive 900W mono amplification at 2Ω, based on discrete components. It was...
