WONDOM AA-BK31382 Mono Class D T-Amp Amplifier Module 2000W 2 Ohm
The Wondom AA-BK31382 is a mono Class D amplifier module capable of delivering no less than 2000W at 2Ω and this with a high efficiency of 90% as well as a high level of detail and very good dynamics.
Reference : 14331
199,00 €tax incl.
165,83 € tax excl.
Wondom AA-BK31382
Wondom AA-BK31382 Module Amplificateur T-Amp Class D Mono 2000W 2Ω
The Wondom AA-BK31382 is a mono Class D amplifier module capable of delivering no less than 2000W at 2Ω and this with a high efficiency of 90% as well as a high level of detail and very good dynamics.  The module is based on a Sure Electronics T-Amp chip, which reduces the distortion level considerably.  The heat-generating components are concealed under a heat sink and a fan to effectively dissipate the heat and protect the hardware.  In addition, overload and overtemperature protections are built into this Wondom AA-BK31382.
Product typeAmplifier module
Amplification ClassClass D
ChannelMono (1)
Amplification chipT-Amp
Power2000W @ 2Ω, 96VDC, THD+N 10%
1500W @ 2Ω, 96VDC, THD+N 1%
InputsSingle-ended line in
Differiential line in
Minimum load impedance2Ω
Efficiency90%
Switching frequency700kHz
BTL Support
Measurements
ParameterConditionsMin.Typ.Max.
Input sensitivity1000W @ 2Ω, 100V, 1kHzSEGain H-0.6Vrms-
Gain L-1Vrms-
DIFFGain H-0.65Vrms-
Gain L-0.9Vrms-
SNR200W @ 4 Ohm, A-WeightingSEGain H-95dB-
Gain L-96dB-
DIFFGain H-94dB-
Gain L-95dB-
THD+N10W @ 4Ω, 1kHzSE-0.02%-
DIFF-0.03%-
100W @ 4Ω, 1kHzSE-0.08%-
DIFF-0.08%-
Input impedanceSEGain H-15kΩ-
Gain L-15kΩ-
DIFFGain H-15kΩ-
Gain L-15kΩ-
Output noise levelA-Weighting, input connected to GNDSE-400uV-
DIFF-350uV-
DC Offset@ 4Ω, 100V-50mV-
Frequency response@ 4Ω, 100V20Hz-20kHz
Gain@ 4Ω, 1kHzGain H-40dB-
Gain L-36dB-
Output monitorGain = 350W @ 2Ω, 100V, 1kHz--39dB-
Power supply72 to 120VDC
Dimensions99 x 99mm
InputPCB Connector
OutputPCB Connector
Channel1 (Mono)
Amplifier chipN/A
Power (W)2000.0
The Wondom AA-BK31382 is a mono Class D amplifier module capable of delivering no less than 2000W at 2Ω and this with a high efficiency of 90% as...
