Bluetooth 2.1 Stereo Amplifier Class D 2x15W 8 Ohm
The Wondom AA-JA32151 JAB 1 is a versatile Bluetooth 2.1 stereo amplifier module delivering 2x15W at 8Ω. This new wondom JAB series offers amplification modules for mobile use. They are optimized for Lithium battery operation. It is possible to use them in mono mode (BTL).
The possibilities of use are great for the design of wireless speakers and loudspeakers: yachting, small sound systems, jukeboxes, home automation, camper vans, in-wall and ceiling speakers... This module can even be used for the DIY design of Bluetooth wireless dock.
Power can be supplied by battery, AC adapter, solar panels, (see PDF in the "Download" tab of this page).
This Bluetooth 2.1 amplifier will allow you to listen to your favourite songs on your audio systems in Bluetooth from a smartphone or tablet. This amplifier is CE and FCC certified.
It can also be used in conjunction with aluminium bracket for wall mounting AA-JA11115 or extension interface with two USB ports, one 3.5mm jack connector and one ON/OFF switch AA-JA11112.
Product type | Amplifier module |
Amplification type | Class D |
Channel | Stereo (2) |
Amplification chip | TPA3116 |
Power | 2x15W @ 8Ω, THD+N < 1% |
Inputs | Stereo input on Molex connector Bluetooth |
Outputs | On Molex 43025-400/43025-4000 connector |
Bluetooth version | 2.1 |
Bluetooth Technology | +EDR A2DP |
LED status indicator | |
Protection | Overcurrents Overheat |
Measurements | ||||
Parameter | Conditions | Min. | Typ. | Max. |
Power supply | - | 12VDC | 19VDC | 24VDC |
Battery under voltage protection | - | - | 10.4VDC | 10.5VDC |
Constant charging voltage | - | 12.5V | 12.6V | 12.7V |
Charge current | - | - | 0.5A | 1A |
Output noise level | A-Weighting, input connected to GND | - | 412µV | - |
Gain | - | 35dB | 36dB | 37dB |
SNR | 19V, 10W @ 8Ω THD+N = 1% | - | 82dB | - |
THD | - | 0.07% | - | |
Output power | 19V @ 8Ω | 2x15W | - | - |
Dimensions | 91.4 x 68.6mm |
Package | 1x Wondom AA-JA32472 JAB 2-30 1x Power cable 50cm |
Input | Molex |
Input | Bluetooth |
Output | Molex |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3116 |
Power (W) | 15.0 |
