WONDOM AA-JA32171 JAB 2-50 Bluetooth 4.0 Stereo Amplifier Class D 2.1 2x50W 4 Ohm
3.1 / 5
Reference : 10847
39,90 €tax incl.
33,25 € tax excl.
This product has been replaced by the new version, the WONDOM JAB2 V2 with DSP.
SURE-AA JA32171
Module 2x50W amplification
JAB2
Here is a versatile Bluetooth 4.0 Stereo amplifier module that delivers 2x50W with 4 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use. They are thus designed to operate on battery power as well as AC. For this purpose the power supply can be battery, AC adapter, solar panels (see PDF in the download tab).
There are many possibilities for designing amplifier / powered speakers: yachting, small sound system, jukebox, home automation, motorhome, In-Wall or ceiling speakers. And more generally, any project requiring flexibility in the integration of the amplifier.
Sure Jab2 2x50 external bluetooth
Version 2018: external antenna bluetooth
This is the 2018 version of JAB2 which now includes a external Bluetooth antenna with adhesive. This enhancement facilitates a clean integration in housing, without sacrificing on the quality of the transfer.
Thus, all Bluetooth applications are gaining flexibility and JAB2 can now be used to develop a high performance Bluetooth dock, active speakers apt-X compatible with wireless apt-X tablets or smartphones.
Many accessories available
This module comes with a 50cm power cable, a 50cm stereo speaker with cable Molex X4 / bare wire. And its external Bluetooth antenna (Version 2018).
Many options and accessories can enhance the JAB2. Awiring kit (Extension, USB charging, Jack Connector 3.5, Switch ON / OFF), a metal mount, battery cradle & power management, LED kit ... etc.
Parts supplied with JAB
Module 18650 external accumulator battery jab
Optionnal battery module
This module can run on batteries thanks to the battery cradle module from the same manufacturer interface. It is a cradle for 18650 battery (Li-Ion 4.2VN). When this accessory is installed, it automatically manages battery charging and powers the amplifier for a very comfortable result with a range of several hours at full power.
1.2.3 battery card connectors are 4-pin connectors to connect the battery with the amplifier card card. This also means that the battery card can load three amplifiers simultaneously.
sure-aa-ja32171-jab-2-50-module-amplific
Product typeAmplifier module
Amplification typeClass D
ChannelStereo (2)
Amplification chipTPA3116
Power2x50W @ 4Ω, THD+N < 1%
Bluetooth version4.0
Bluetooth technologyaptX
+EDR
A2DP
InputsStereo input on Molex connector
Bluetooth
Status indicatorBy LED (not included)
ProtectionOvercurrent
Overheat
Measurements
ParameterConditionsMin.Typ.Max.
Power supply-12VDC19VDC24VDC
Battery under voltage protection--10.4VDC10.5VDC
Constant charging voltage--12.3V12.7V
Chargin current--0.5A1A
Gain-18dB26dB36dB
Output power19V @ 4Ω2x50W-
THD@ 4Ω, 10W, 1kHz-0.02%-
Output noise levelA-Weighting,input connected to GND-185µV-
SNR10W @ 4Ω, THD+N = 1%-92dB-
Dimensions91.5 x 68.5 x 23mm
Package1x Wondom AA-JA32472 JAB 2-30
1x Power cable
1x Speaker cable
InputXH 2.54mm
OutputMolex
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
7 reviews
Sound quality isn't great, the board is noisy
It has high noise, bluetooth stopped working quite soon after the purchase (2018), loud crosstalk from line input while bluetooth and so on. Cannot use with all the attachments, like Jab3 and batter pack because they utilize same connector. It is feature packed product with great expectations, but a disappointment and would not recommend purchasing this product. While it works, it is cumbersome and just poor quality.
That said, purchased it 2018 and now 5 years later it still works apart from the bluetooth so in this sense it's fine. Just do not expect anything from such cheaply made product.
This review has been posted for WONDOM AA-JA32171 JAB 2-50 Bluetooth 4.0 Stereo Amplifier Class D 2.1 2x50W 4 Ohm
Très correct pour le prix
Bien fini, plug and play, rien a faire a part brancher et écouter. Pas de bruit parasite pour la part mais le son n'est pas non plus exceptionnel. Je l'ai installé dans une radio année 50 en remplacement du système d'origine. Cela suffit amplement pour l'usage dédié (écoute en volume modéré dans un bureau). Couplé a une alim 19v et des HP alpine 4ohm.
Boombox qui renaît de ces cendres
Idéal pour moderniser une Boombox des années 90 sortie du grenier avec remplacement des Hp par des Focal ISS. C'est pas compliqué, tu branches, ça marche. Aucun problème pour ma part.
Très bon produit
Pas de souffle de mon côté (utilisation bluetooth avec iphone SE et ipad air), son très correct et suffisamment puissant, en tout cas suffisant pour moi (transformation TSF en HP bluetooth). Livré avec cable mono HP mais sortie dispo pour stereo.
A associer avec panneau de contrôle Dayton.
Bravo pour la disponibilité et la reactivité de l’equipe Audiophonics.
Parasites
Exactement le meme parcours que Stephane, des gros parasites, souffles et meme un beat étrange. Testé avec plusieurs alim, impossible de trouver la cause.
Super SAV, très cordial et réactif. J'ai renvoyé le produit.
