WONDOM AA-JA32175 JAB2+ Amplifier Module
Wondom's JAB2+ is a stereo amplifier module featuring a Bluetooth 5.0 module and integrated DSP. The JAB2+'s amplification is based on a Texas Instrument TPA3116 chip capable of delivering 35W per channel at 4Ω. For furthermore flexibility, it is also possible to configure a single 100W output at 4Ω.
Reference : 19768
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 23-04-2025.
Wondom AA-JA32175 JAB2+ Amplifier Module 2.1 Class D Bluetooth 5.0 2x50W 4 Ohm
WONDOM AA-JA32175 JAB2+ : 3/4view
The Bluetooth connection coupled with the concert mode of this module allows it to connect to a maximum of 256 units wirelessly, making it ideal for various audio projects such as portable speakers, bookshelf speaker installations or pure DIY applications.
Wondom AA-JA32175 JAB2+: Wireless connection and DSP
The JAB2+ incorporates a Bluetooth module and a DSP module. Where the Bluetooth module lets you seamlessly connect remotely to stream music from your devices, the DSP module gives you access to advanced signal processing capabilities such as a 10-band EQ, crossover, delay, phaser and much more.
Wondom AA-JA32175 JAB2+: PBTL and gain setting
The JAB2+ benefits from increased flexibility thanks to its support for PBTL configuration so that it can function as a mono amplifier module, a very useful function in cases where only one high-power channel is required, such as a subwoofer, for example. Furthermore, this module has a choice of gain level settings between 20dB and 26dB, allowing you to adapt the amplifier's output level to suit your source and drivers.
WONDOM AA-JA32175 JAB2+ : TPA3116 Chip
Wondom AA-JA32175 JAB2+: TPA3116
The JAB2+'s power supply stage is based on a Texas Instrument TPA3116 chip, enabling this module to deliver 35W at 4Ω per channel in a stereo configuration or 100W at 4Ω in a mono configuration. The JAB2+'s dedicated PCB enables it to achieve a signal-to-noise ratio of 104.2dB, guaranteeing you quality sound without distortion, whether you're powering a professional audio installation or a home cinema system.
Wondom AA-JA32175 JAB2+: 4.0 / 2.1 and concert mode
The JAB2+'s wireless connection isn't just useful for connecting to it from your devices, you can also connect another JAB2+ to it to create a 4.0 or 2.1 installation. Furthermore, in concert mode, you can use several modules to broadcast audio from the same source without any delay thanks to the synchronisation of the drivers, allowing you to extend your installation as much as you wish for.
WONDOM AA-JA32175 JAB2+ : 4.0 / 2.1 et concert mode
Wondom AA-JA32175 JAB2+: Designed to last
The JAB2+ amplifier module is built to last, incorporating a comprehensive two-layer protection system that includes independent circuits for the power supply circuit and the output stage. The power section is protected against overvoltage, overcurrent and reverse polarity, making it immune to potentially damaging power problems. The output stage is protected against overcurrent, direct current, output short circuit and overtemperature, ensuring operational integrity and longevity.
WONDOM AA-JA32175 JAB2+ : Module details
Type of productAmplifier module
Amplification chipTPA3116
Output power (stereo)2x35W @ 4 Ohm, 24V, 1% THD
2x50W @ 4 Ohm, 24V, 1% THD
Output power (mono)100W
Number of channels2
Signal-to-noise ratio (SNR)104.2dB
Protection against overcurrent and overheatingYes
Inputs1x Line in
1x Jack 3.5mm AUX input
Bluetooth
Bluetooth version5.0
Power supply12V-24V
Dimensions91.44mm x 68.58mm
Package1x Wondom AA-JA32175 JAB2+
50cm power cable
1x 50cm speaker cable
InputJack 3.5mm
InputAUX
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)35.0
WONDOM AA-JA32175 JAB2+ Amplifier Module 2.1 Class D Bluetooth 5.0 2x35W 4 Ohm
Wondom 's JAB2+ is a stereo amplifier module featuring a Bluetooth 5.0 module and integrated DSP. The JAB2+'s amplification is based on a...
