WONDOM AIPO2X3 Amplifier Module
The WONDOM AIPO2X3 amplifier module is a small stereo amplifier module capable of delivering 2x3W @ 4 ohms thanks to a Class D PAM8408 amplifier chip with integrated volume control.
Reference : 19550
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 23-04-2025.
Wondom AIPO2X3 Stereo Amplifier Module 2x3W @ 4 ohm
WONDOM AIPO2X3 module picture
The Wondom AIPO2X3 amplifier module is a small stereo amplifier board capable of delivering 2x3W @ 4 ohms thanks to a Class D PAM8408 amplifier chip with integrated volume control. The special feature of this module is its adaptability and versatility, thanks to an integrated DC/DC loop circuit supporting a wide range of power supplies from 9V to 60V. It withstands challenging environments, including temperatures ranging from -35°C to 75°C, and features a complete protection circuit. These features make it ideal for industrial applications such as gaming machines, vending machines, electric bicycles and DIY audio projects.
Key features of the WONDOM AIPO2X3 module :
  • 2x3W RMS power @ 4 ohm
  • PAM8408 Class D amplifier chip
  • Operating temperature from -30°C to 75°C
  • Overload, temperature, short-circuit and reverse polarity protection circuitry
  • Integrated volume control and external control connector
  • Easy integration and plug-and-play system
  • Compact form factor
WONDOM AIPO2X3 module overview
1Microfit-2 power supply input
2Line input JST-5
33.5mm jack input
4External control port JST-6
5Volume control knob -
6Volume control + button
7PAM8408 amplification chip
8Amplified audio output on Microfit-4
WONDOM AIPO2X3 dimensions
Product typeAmplifier module
Amplification chipPAM8408
Channel number2
Inputs1x Stereo line input on Microfit PCB connector
1x 3.5mm jack stereo line input
Output1x Stereo output on Microfit PCB connector
Volume control
AUDIO Performances
ParametersConditionsMin.Typ.Max.
Gain--13dB25dB
Input sensitivityRl=4Ω-800mW RMS-
Input impedanceLine input-10KΩ-
Output powerRl=4Ω-2x3W-
Bandwidth @ +/-3dBVCC=24V, Rl=4Ω, 2x3W20Hz-20kHz
THD+N1W, Rl=4Ω, 1kHz-0.05%-
Output noise levelEntré connecté à GND, A-weighted-104µV-
SNR2x3W, Rl=4Ω, A-weighted-88.7dB-
Electrical Spefications
Operating voltageDC supply voltage, Rl=4Ω92460
Idle powerVCC=24V, Rl=4Ω-0.48W-
Standby powerVCC=24V, Rl=4Ω-0.144W-
Power conversion circuit efficiencyVCC=24V, Po=6W-71.4%-
Overall efficiencyVCC=24V, Rl=4Ω, 2x3W-68%-
Minimum load impedanceVCC=24V, Rl=4Ω, 2x3W--
Total dimensions50.8 x 76.2 x 19.1mm
Package1x Wondom AIPO2X3 amplifier module
1x Audio output cable Microfit 2-pole to bare wire 50cm
1x Power cable Microfit 4-pole to bare wire 50cm
WONDOM AIPO2X3 measurements
InputPCB Connector
OutputPCB Connector
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipPAM8408
Power (W)3.0
WONDOM AIPO2X3 Stereo Amplifier Module 2x3W 4 ohm
The WONDOM AIPO2X3 amplifier module is a small stereo amplifier module capable of delivering 2x3W @ 4 ohms thanks to a Class D PAM8408 amplifier...
