Für Leute wie mich, die nicht Leer-Platinen, Anschlüsse für Printmontage und Klemmblöcke rumliegen haben, eine einfache Lösung. Elektroniker basteln eher selber etwas zusammen.
This module offers a wide range of connectors to easily connect a module and a power supply that use different connectors. It has the majority of connector models an will cover almost all possible scenarios for devices prototyping, modification and repair.
All the POSITIVE on the board are connected and all the NEGATIVE are connected. The only difference being on the connectors used.This module is not intended to group several power supplies & modules together , but to act as a generalized adapter to connect a module to a power supply whatever connections are available
It is particularly useful for quickly interchanging / testing power supplies and modules in order to compare their performance.
J1, J2, J22, J23 | Screw terminal Max 40A |
J14, J15 | DIN 4 Pin |
J16, J17 | Jack DC 5.5/2.5 mm |
J19, J10, J13, J6, J7 J11, J12, J8, J15 | RJ128 terminal (type phoenix) |
J3, J4, J20, J21 | Banana jack (30VAC / 60VDC Max 24A) |
J26, J27, J28, J29 | Flag connector |
J18, J19 | Molex MiniFit 4 poles 4.2mm Max 13A / AWG 16-18 |
Caractéristiques | |
Type | Power Supply Breakout Board |
Dimensions | 91.44 x 68.58 mm |
Input |
Output |
Channel |
Class |
Amplifier chip |
Power (W) |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Andreas L.
