With the DKT2X20AB, Wondom offers a DIY kit to assemble a 2x20W Class AB amplifier module yourself. Designed with a TDA7576B chip, this kit offers 20W output per channel at 4Ω, guaranteeing high-fidelity sound with low noise. Equipped with a robust heatsink, the DKT2X20AB benefits from an optimal cooling design for increased durability and longevity.
With an exhaustive step-by-step assembly guide, this kit makes an excellent entry point into the world of DIY audio, giving you the satisfaction of building your own audio system.
Wondom's DKT2X20AB kit is designed to deliver 2x20W output into 4Ω when powered from 24V DC. This amplification is the result of a TDA7576B chip, integrating within it a MOSFET power stage coupled with BCD (Bipolar-CMOS-DMOS) technology for a final rendering of great finesse with a background noise of only 60µV.
The DKT2X20AB kit has been designed with ease of use and installation in mind. Its terminals allow direct connection to the power supply, audio input, speaker outputs and external control systems. The inclusion of a 3.5mm jack auxiliary input makes it even easier to connect to a wide range of sources, making the DKT2X20AB compatible with a wide range of devices. Finally, support for a voltage range from 12V to 24V DC ensures extensive compatibility with a variety of power sources for seamless integration into any audio installation.
The DKT2X20AB kit features a gold-plated PCB, offering a superior quality finish. This gold plating not only improves the reliability of the solder joints, but also the conductivity of the circuit, providing excellent corrosion resistance, which is crucial to the stability and longevity of the amplifier.
The DKT2X20AB amplifier board features an improved cooling system that includes a heat sink as large as the printed circuit board. This massive heatsink ensures efficient heat dissipation, even when the amplifier is operating at full capacity. As a result, the DKT2X20AB can maintain optimum performance over a wide temperature range from -10°C to 55°C.
By following the DKT2X20AB step-by-step assembly guide, you'll find it easy to assemble this kit, just rely on the following steps and refer to the user manual for precise positioning of each component.
1. Install the SMD resistors:
Place the SMD resistors on the top and bottom faces of the board, respecting their respective positions.
2. Install ceramic capacitors and fuses:
Install the ceramic capacitors and fuses in the correct position. Ensure that the wires are correctly inserted and soldered.
3. Install electronic capacitors and through-hole inductors :
Install the electrolytic capacitors and the inductor with the hole in the area provided. Make sure that the polarity of the (+) and (-) wires of the electrolytic capacitors is correct before soldering them.
4. Attach the TDA7576B chip to the heat sink:
Screw the IC to the heat sink using an M3 screw in the dedicated slot and secure firmly.
5. Installing the integrated circuit and heat sink:
Once the integrated circuit is attached to the heat sink. Place the integrated circuit and the heat sink in the position provided on the board.
6. Install the remaining components:
Install the remaining components on the printed circuit board. Take care to align each component correctly and solder them securely.
Product type | Amplifier module kit |
Type of amplification | Class AB |
Amplification chips | TDA7576B |
Power | 2x 20W @ 4Ω, 24V, 1% THD+N 2x 25W @ 4Ω, 24V, 10% THD+N |
Total harmonic distortion more noise (THD+N) | 0.05% @4W 1kHz |
Output noise | 60µV |
Input impedance | 55kΩ |
Crosstalk | 65W @ 4W 1kHz |
Operating temperature | -10°C ~ 55°C |
Power supply voltage | 12V - 24V DC |
Dimensions | 82.55 x 63.50 x 31.75mm |
Package | Sold by unit (cable and screws not supplied) |
Input | PH 2.0mm |
Input | Jack 3.5mm |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | TDA7576B |
Power (W) | 20.0 |
