WONDOM JAB 2 AA-JA11114 Functional Cables Package for Wondom JAB1 / JAB2 Module Amplifier
The Wondom AA-JA11114 cable package is a set of cables specially designed to enable users to quickly and easily operate the JAB1 / JAB2 modules and their various functions.
4.0 / 5
Reference : 10850
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 23-04-2025.
Wondom AA-JA11114 Functional Cables Package for Wondom JAB1 / JAB2 Module Amplifier
Photo du package de câbles Wondom AA-JA11114
The Wondom AA-JA11114 cable package is a set of cables specially designed to enable users to quickly and easily operate the JAB1 / JAB2 modules and their various functions. This package includes :
  • Bluetooth / Power / Charge LED indicators
  • Line input cable 3.5mm jack
  • Cable and potentiometer for volume control + ON/OFF switch
  • 4-pin PH cable for use with Wondom AA-JA11113 module (sold separately) and 3S 18650 Lithium batteries (sold separately)
  • Cable and button for Bluetooth control
Exemple de connexion avec un JAB2v2 (vendu séparément)
Exemple de connexion d'un Wondom JAB2
Technical characteirstics
Product typeFunctionnal cable package for Wondom JAB1 / JAB2
Package content1x External Bluetooth antenna 10cm
1x Cable and Bluetooth control button 50cm
1x Battery charging cable 50cm
1x Switch cable 50cm
1x Jack 3.5mm line input cable 50cm
1x Cable and volume potentiometer
3x Cables and LED indicator (1x blue, 1x green, 1x red) 50cm
1x Antenne Bluetooth externe 10cmBluetooth cable and control button Bluetooth cable and control button 50cmIndicateurs LED Bluetooth / Power / Charge
InputNC
OutputNC
ChannelN/A
ClassN/A
Amplifier chipN/A
Power (W)N/A
4 reviews
indispensable
permet une installation propre et le potar est même indispensable à mon avis (posté sur JAB2V2)
This review has been posted for WONDOM JAB 2 AA-JA11114 Functional Cables Package for Wondom JAB1 / JAB2 Module Amplifier
Sure jab 2AA
Très simple à connecter.
Le seul problème c'est le potentiomètre de volume qui crache quand on le tourne... Il faudrait améliorer ce point.
faisceau obligatoire
aussitôt reçu, aussitôt installé avec le module JAB2 2*30W 8ohms. On peut dire que la connectique est "facile", tu branches ça marche. Pour ma part, j'ai juste connecté le voyant bleu, les sorties HP, l'alim et le bouton volume. (ce dernier à tendance à crachoter à très faible volume sur la voix de droite... problème de qualité???)
La longueur des faisceaux est suffisantes pour une intégration dans une enceinte BT. c'est du DIY avec du vrai bois et pas de ces enceintes en plastoque qui font un bruit horrible... Là on est franchement sur de la qualité.
Concernant l'envoi c'est parfait, et en cas de problème le SAV est très réactif. bravo!
Perfectible
Malgré un prix peu élevé il est à noter ceci : Les douilles des témoins semblent forées en 6mm pour des leds 5mm qui évidemment se mettent en diagonale dedans, c'est pas très esthétique... la led verte (power) va bien plus fort que les autres, c'en est même dérangeant, j'ai du changer la résistance en série. Le témoin de charge (led rouge) est une véritable plaisanterie, pour déterminer le niveau de charge elle va simplement plus ou moins fort... et contrairement à la logique elle est allumée plus fort lorsque la charge est faite pour s'éteindre lorsque les batteries sont vides... on aurait en effet plus tendance a vouloir voir un voyant rouge s'allumer voire clignoter pour dire "batterie faible" que l'inverse... Bref j'aurais préféré mettre 10€ de plus pour des voyants de qualité, le système de contrôle de charge quant à lui mérite une ré-étude complète. le potentiomètre de volume ainsi que le reste font le travail demandé et sont de qualité correcte.
The Wondom AA-JA11114 cable package is a set of cables specially designed to enable users to quickly and easily operate the JAB1 / JAB2 modules and...
