WONDOM JAB3+ AA-JA32474 Class D Amplifier Module
The Wondom JAB3+, part number AA-JA32474, is an amplifier module capable of developing 2x 30W power at 8 Ohm, and featuring Bluetooth 5.0 (aptX HD) functionality as well as an ADAU1701 DSP chip. Thanks to this DSP chip, the JAB3+ is an all-in-one amplifier module that can be programmed with SigmaStudio, AppControl and PC UI when coupled with a Wondom ICP programmer (ICP5, for example).
Reference : 18622
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 24-04-2025.
WONDOM JAB3+ AA-JA32474 Class D Bluetooth 5.0 Amplifier Module ADAU1701 DSP 2x30W 8 Ohm
Photo of Wondom JAB3+ AA-JA32474
The Wondom JAB3+, part number AA-JA32474, is an amplifier module capable of developing 2x 30W power at 8 Ohm, and featuring Bluetooth 5.0 (aptX HD) functionality as well as an ADAU1701 DSP chip. Thanks to this DSP chip, the JAB3+ is an all-in-one amplifier module that can be programmed with SigmaStudio, AppControl and PC UI when coupled with a Wondom ICP programmer (ICP5, for example). This gives you access to settings such as volume, gain, frequency and equalization. In addition to its speaker output, the JAB3+ features an additional mixed audio output, which can be used with another amplifier module to create a 2.1 or 4.0 system. The PC UI interface can then be used to configure the amplifier in mono or stereo mode. The JAB3+ can also be battery-powered with Wondom BCPB module series to create a portable, high-performance audio system.
Wondom JAB3+ AA-JA32474 connection diagram
WONDOM JAB3+ AA-JA32474: Bluetooth 5.0
A Bluetooth 5.0 interface enables the Jab3+ to support high-resolution Bluetooth codecs: SBC, AAC, AptX, aptX LL and aptX HD. A receive antenna is integrated directly into the module for direct use, but an external antenna port is also present to ensure stable data transmission and high audio performance if the JAB3+ is installed in a speaker or enclosure.
Bluetooth functionality of the Wondom JAB3+ AA-JA32474
Photo of Wondom JAB3+ AA-JA32474 potentiometer connectors
WONDOM JAB3+ AA-JA32474: ADAU1701 DSP chip
Audio signal processing is handled by an ADAU1701 DSP chip. Four ports allow external potentiometers (sold separately) to be fitted. These allow you to control volume, gain, bass and treble levels. Used in conjunction with a Wondom ICP5 module (sold separately), you can then adjust numerous audio parameters via SigmaStudio software or a control application.
Wondom JAB3+ AA-JA32474 control method compatibility chart
WONDOM JAB3+ AA-JA32474: 3.5mm jack line input
In addition to its Bluetooth input, the Jab3+ features a 3.5mm jack line input. The signal from the two inputs can be mixed before being sent to the amplifier circuit. The AUX 3.5mm cable is supplied in the JAB3+ functional cable kit (AA-JA11117).
Photo of Wondom JAB3+ AA-JA32474 3.5mm AUX port PCB connector
Photo of Wondom JAB3+ AA-JA32474 coupling with Wondom BCPB battery module
WONDOM JAB3+ AA-JA32474: Support for battery powering
In addition to the option of a DC 12-26V power supply, the Wondom JAB3+ AA-JA32474 amplifier module supports battery power, greatly enhancing the module's portability. As the JAB3+ is not equipped with a charging circuit, the use of Wondom BCPB modules is recommended.
WONDOM JAB3+ AA-JA32474: energy consumption control system
A sensor system monitors the input signal. It enables the Wondom JAB3+ AA-JA32474 to automatically switch to standby if no signal above the detection threshold is detected for 5 minutes. When a signal is detected, it switches back on automatically.
Wondom JAB3+ AA-JA32474 connectors
Product typeAmplifier module
Number of channels2.0
DSP ChipADAU1701
Amplification chipTPA3116 + TPA3118
Output power2x 30W @ 8 Ohm
InputsBluetooth 5.0
1x 3.5mm line input jack
Outputs1x Speaker output on PCB connector
1x Line output on PCB connector
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Mesures
ParameterConditionsMin.Typ.Max.
Minimum load impedance-5.6Ω8Ω-
Efficiency2x30W @ 8Ω, 1kHz-88%
Amplifier gain@ 8Ω, 20Hz-20kHz-25.8dB-
DSP gainSE1 (Speakers output) @8Ohm, 1kHz-60dB-0dB
SE2 (Line output) @8Ohm, 1kHz-60dB-6.5dB
Input sensitivity2x 30W@8Ohm, 1kHz, 23.5dB-770mV-
Gain filterButterworth, Q= 0.707-4dB-
Cutoff frequencyHFP0.25kHz-2kHz
LFP-20kHz-
SNR2 x 30W @ 8Ohm, THD+N=1%, 25.8dB, A-weighting-91dB-
THD+N5W @ 8Ohm, 1kHz, 25.8dB-0.037%-
10W @ 8Ohm, 1kHz, 25.8dB-0.039%-
Input impedance--10KΩ-
Supported sample rates--48KhZ-
Output noise levelA-weighed, input connected to GND, 25.8dB-163uV-
DC offset--10mV-
Max output levelJ7, Line output connector-1.94dBu-
Crosstalk separation20Hz-20kHz, Gain=26dB--60dB-
Nominal power requirement@ 24V, 1kHz-68W-
Operating volatge@ 1kHz, 8 Ohm12V24V26V
Idle powerSignal detected-1.8W-
No signal detected-105mW-
Dimensions91.44 x 68.6mm
Package1x Wondom JAB3+ AA-JA32474 amplifier module
1x Power cable Molex connector to bare wires (50cm)
1x Speaker cable Molex connector to bare wires (50cm)
Wondom JAB3+ AA-JA32474 measurements
InputPCB Connector
OutputPCB Connector
OutputMolex
Channel2 (Stereo)
Amplifier chipTPA3118
Amplifier chipTPA3116
Power (W)30.0
The Wondom JAB3+, part number AA-JA32474, is an amplifier module capable of developing 2x 30W power at 8 Ohm, and featuring Bluetooth 5.0 (aptX HD)...
