AUDIOPHONICS PGA TA2022. DIY Amplifier Kit with Remote Control
By buying this product you get 34 loyalty points
Reference : 7000
349,00 €tax incl.
290,83 € tax excl.
This kit contains all the elements necessary to the assembly of a digital stereo amplifier based on the high performance circuitTRIPATH TA2022.
This amplifier is equipped with the module PGAVOLwhich offers an input selector and volume control via the front rotary encoder or remote control.
The housing is completely drilled to incorporate the kit elements as easily as possible.No drilling is required.
This realization requires very few tools to be able to be carried out.
The assembly is within everyone's reach and is a royal way to learn the joys of the DIY at a lower cost, with the ultimate achievement of a quality device, and the satisfaction of having made yourself the " one of the components of his Audio system.
https://www.audiophonics.fr/images2/7000/7000_AP_PGA_TA2022_5.jpg
https://www.audiophonics.fr/images2/7000/7000_AP_PGA_TA2022_1.jpg
Designed on aAUDIOPHONICS loads, this assembly is characterized by its musicality of high flight and its impressive power with regard to its compactness.
The chipTA2022integrated, it is possible to achieve 2 x 90 Watts under 4Ω with a level of harmonic distortion extremely well controlled since not exceeding 0,1%.
In order to exploit the possibilities of this circuit prodigy, we have chosen to integrate components of higher quality, such 12 ELNA capacitorsof each one1200uF / 63V, cleverly allied to MKP, as well as a generously sized toroidal transformer.
https://www.audiophonics.fr/images2/7000/7000_AP_PGA_TA2022_6.jpg
https://www.audiophonics.fr/images2/7000/7000_AP_PGA_TA2022_4.jpg
https://www.audiophonics.fr/images2/5805/5805_PGAVOL_4.jpg
Features:/ strong>
  • Enclosure with aluminum front 3mm Black
  • Operation with ON / OFF button illuminated with a Blue Halo
  • Signal input on 24k gold-plated RCA headers
  • Outputs on HP High Quality 24k Gold plated terminals and accepting cables of large cross section, as well as forks and banana plugs
  • IEC anti-interference power connector with built-in EMI filter
  • Capacitors Panasonic FC 12x1200μF & MKP
  • Offset Setting Possible
Specifications:
  • Inputs: 4 stereo RCA input
  • Control: input selection and volume control on the remote control
  • Output Power per Channel: 60W / 8Ω (0.1% THD + N)
    90W / 4Ω (0.1% THD + N) ²
  • Total Harmonic Distortion Rate: 0.015% at 45W 8Ω
    0.015% to 70W 4Ω
  • Intermodulation Distortion Rate (SMPTE): 0.10% to 25W 4Ω
  • Dynamic Range: 102dB
  • Yield: 92% to 88W / 8Ω
    87% at 125W / 4Ω
  • Power Supply: 150VA Toric Transformer (2 x 24V + 9V + 12V)
  • Dimensions:435 x 300 x 120 mm (L x W x H)
  • Weight:7.2 kg
Projet très intéressant. Dommage que la conception globale n'ait pas été revue pour éviter les multiples condensateurs de liaison et optimiser le trajet du signal.
j'aurais finalement préféré un vrai kit PGA (avec boitier perforé!) qui propose enfin une alternative correcte aux modèles chinois.
This review has been posted for AUDIOPHONICS PGA TA2022. DIY Amplifier Kit with Remote Control
