AECO ABC-1471 BNC Connectors 75 Ohm Beryllium Copper Gold Plated Ø10mm (Pair)
The aeco ABC-1471 are 75Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with 10µ gold plating, providing excellent conductivity and protection against oxidation.
Reference : 18043
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-04-2025.
aeco ABC-1471
Connecteurs BNC 75 Ohm Cuivre Beryllium Plaqué Or (La paire)
aeco ABC-1471 Connecteurs BNC 75 Ohm Cuivre Beryllium Plaqué Or (La paire)
The aeco ABC-1471 are 75Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with 10µ gold plating, providing excellent conductivity and protection against oxidation. The body is made of brass to make the connector extremely robust. The cable, with a maximum diameter of Ø7.5mm, can be fitted by soldering or crimping.
Product typeBNC connectors
Contacts materialBeryllium copper (purity: ≥ 97%)
Contacts platingGold 10µ
ShellBrass
Impedance75Ω
Frequency range1GHz
VSWRUp to 1.2
Contact resistance< 0.1mΩ
Max cable diameterWith reducer: Ø8.5mm
Without reducer: Ø10.5mm
Total dimensionsØ14.5*42mm
Quantity2 connectors
Max cable diameter (mm)10.5
Mounting typeTo crimp
Mounting typeTo weld
ConnecticMale
Max panel thickness (mm)N/A
Impedance (Ω)75
Contacts Material (Connector)Beryllium Copper
The aeco ABC-1471 are 75Ω BNC connectors featuring a very high quality design. They feature high-purity beryllium copper contacts with...
