CANARE BCP-B4F Connector BNC 75 Ohm High Performances to Crimp
Reference : 13290
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 23-04-2025.
CANARE BCP-S4S
Crimp high performance
This 75Ω BNC BCP-D55UHD, designed and manufactured in Japan by Canare firm is the guarantee of a product of very high quality. It was designed to fit perfectly on the following coaxial cable models: L-4CHD / L-4CFB / 1505A. It may of course be adapted to other coaxial cables.
This connector consists of three parts. The main portion, the central pin, billet and gold plated, which will be placed on the inner conductor of the cable and a ring which will crimp the connector to the cable. The external contact is made of Beryllium Copper.
Note: The assembly of this connector requires a special crimping tool developed by the mark (sold separately).
Type connectorBCN Male
Pin central platingGold
outside Contactcopper Beryllium
Loss Rates (0-3GHz)26dB or +
traction Force245N
coupling sleeveZinc alloy
Weight12.5g
Dimensions31 x ⌀14.6mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Max panel thickness (mm)N/A
Impedance (Ω)75
Contacts Material (Connector)Beryllium Copper
