CANARE BCP-D55UHD BNC Connector 75 Ohm High Performances to Crimp Ø7.7mm
This BNC 75Ω BCP-D55UHD connector, designed and manufactured in Japan by Canare is the assurance of a very high quality product. This one has been designed to fit perfectly on the Canare L-5.5CUHD 12G-SDI coaxial cable. It can of course be adapted on other coaxial cables.
Reference : 12957
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 22-04-2025.
CANARE BCP-D55UHD
CANARE BCP-D55UHD Connector 75 Ohm High Performances to Crimp Ø 7.7mm
CANARE L-5.5CUHD Câble Coaxial Ultra Faible Perte 75Ω Blindé Hautes Performances Ø 7.7mm
This connector consists of 3 parts. The main part, the central pin, machined from the ground and gold-plated, which will be placed on the inner conductor of the cable and a ring that will crimp the connector to the cable. The external contact is made of Beryllium Copper.
Note : The assembly of this connector requires a specific crimping tool developed by the brand (sold separately).
Canare L-5.5CUHD Câble Coaxial 12G SDI
A connector designed for the Canare L-5.5CUHD cable
The Canare L-5.5CUHD cable has the standard 12G-SDI. This allows a higher transmission and acquisition speed of video streams, particularly suitable for 4K and UHD at 60fps. These cables thus ensure a signal transmission speed of 12Gbps while being less heavy and cumbersome than 4 cables 3G-SDI.
Moreover, the design of this cable also ensures much less signal loss and therefore the possibility of using a longer length while maintaining a stable signal.
The cable is sold separately, by the meter.
Connector typeMale BNC
Center pin platingGold
External contact materialBeryllium copper
Return less0-3GHz : >= 26.4dB
0-6GHz : >= 20dB
0-12GHz ! >= 15dB
Pull strength>= 200N
Total dimensions of the main part31 x ⌀14.6mm
Weight14.5g
ColorSilver
Recommanded cableCoaxial cable 12G-SDI Canare L-5.5CUHD
Max cable diameter (mm)7.7
Mounting typeTo crimp
ConnecticMale
Max panel thickness (mm)N/A
Impedance (Ω)75
Contacts Material (Connector)Beryllium Copper
3 reviews
Parfait
Belle qualité de fabrication et contact semblant excellent.
Le montage de ce connecteur BNC reste assez facile.
This review has been posted for CANARE BCP-D55UHD BNC Connector 75 Ohm High Performances to Crimp Ø7.7mm
incontournable
Je l'utilise depuis un bout de temps pour mes câbles numériques.
Et n'en connais pas d'autre pour assurer une impédance à 75ohm grâce au montage sans soudure à sertir
Excellent produit
Rien à redire sur la qualité de ce produit qui est conforme à mes attentes.
This BNC 75Ω BCP-D55UHD connector, designed and manufactured in Japan by Canare is the assurance of a very high quality product. This one has been...
