Female BNC IC Connector 75 Ohm Gold Plated Ø12mm (Unit)
Here is a simple and efficient gold-plated BNC baseplate for the design of DAC audio input or digital audio output to the SPDIF 75 Ohm standard.
Reference : 12291
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 11-04-2025.
BNC SOCKET FOR SPDIF PRINTED CIRCUIT
BNC circuit châssis femelle plaqué Or<br /> This Gold-Plated BNC Plug-in Solder Connector allows you to properly design an output or input to the SPDIF 75 Ohm standard. It is particularly suitable for= "https://www.audiophonics.fr/en/diy-interfaces/audiophonics-digipipro-raspberry-pi-2-pi-3-i2s-digital-interface-p-12150.html" target = "_ blank">the SPDIF 24bit 192Khz digital output card for Raspberry Pi3 AUDIOPHONICS DIGIPi + PRO on GPIO connector. Example: AUDIOPHONICS DIGIPI + PRO card not included
quotation BNC chassis PCB plated Gold SPDIF
TECHNICAL CHARACTERISTICS
  • Connector type: BNC female 75 Ohm plated Gold solder on printed circuit
  • Diameter of boring: 12mm
  • Man panel thickness: 6mm
  • Supplied with a nut and chassis clamping washer
embase BNC SPDIF plaqué Or
This connector is delivered individually.
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.0
Impedance (Ω)75
